Old 04-20-2022, 01:45 AM   #1
64stpside
Possible to shorten a factory 64 C10 steering column?
It's the stk 3 speed manual column. Truck has been converted to a s10 5 speed.
Not looking to swap the column to something else if possible.
I saw this thread for the later model trucks, would this work?
https://67-72chevytrucks.com/vboard/...d.php?t=191143
64stpside is offline   Reply With Quote
Old 04-20-2022, 06:58 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Possible to shorten a factory 64 C10 steering column?
Looks like they moved it forward. The problem with the linkage not working properly would be my first guess.
The length of the column shaft from the end of the column to the steering box would have to be changed.
I don't think the mounting slots on the column would be long enough:
Old 04-20-2022, 07:02 PM   #3
KVB
Read through this blog. A great source for T5 info.
https://lugnutz65chevystepside.weebly.com/steering-column-modification.html
He is on this site, not sure if his handle is Lugnutz or not.
Ken
KVB is offline   Reply With Quote
Old 04-20-2022, 08:35 PM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Look for a 67-69 floor column, it will look a lot like a 63-66 but has an intermediate shaft that you can collapse.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-21-2022, 10:00 AM   #5
SCOTI
SCOTI's Avatar
Yes the original column can be shortened since you're no longer using the column linkage w/the s10 5spd swap.
Board member @gringoloco shortened/modified an original 3spd column like yours. It's a great build thread but the info you want will be starting @ pg77 post #1924......
http://67-72chevytrucks.com/vboard/s...d.php?t=444746
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
