Old 04-20-2022, 11:15 PM   #1
steves1967
steves1967's Avatar
Can I trim down the cooling fins?
Im pretty limited on options as to where to place the computer. If i trim down the cooling fins I could slide it in above the AC box.
'71 Chevy 3/4 Ton Longbed
'22 Chevy Tahoe RST
'67 Firebird- 8 sec street car
'24 GMC CC 4x4 Duramax Dually
steves1967 is offline   Reply With Quote
Old 04-21-2022, 09:05 AM   #2
Davidf
Re: Can I trim down the cooling fins?
Not sure. But, since the computer will be living inside the cab, it wont see the heat it would under the hood where it lived originally. So, I am guessing you will be ok.
Davidf is offline   Reply With Quote
Old 04-25-2022, 01:10 PM   #3
EagleChief
EagleChief's Avatar
I would think you'd be ok. I just used mine as a mounting point and drilled holes through them for a bracket.
I had the same concern, but went ahead and did it.
1971 C10 - Hugger Orange/White
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=780197
LS Swap Thread: https://67-72chevytrucks.com/vboard/...d.php?t=811460
EagleChief is offline   Reply With Quote
