Anyone running 15" X 10" rear wheels
I would like to run a 15" X 10" rear wheel. Just wondering if it will fit good without modifying anything. Also what backspacing is best and offset. Thanks
#2 | |
Re: Anyone running 15" X 10" rear wheels
67-72's are @ least 50yrs old so it's possible a different rear end housing is under the truck. The 71-72 rears are wider vs the pre-disc brake trucks. Which rear end housing you have impacts the numbers. That being said, 15x10's will fit under these trucks. Backspacing depends on personal tastes, rear end width, & vehicle height.
I do not have offsets, but 15 x 10 fits without a problem. I can almost get 12" wide tires under the truck, but the sectional width of the tires make them about 1" too wide depending on the height of the truck in the rear.
![]() Join Date: Dec 2013
The problem isn't using a 10" wide wheel the problem is what tires are you going to use that are tall enough to not make your truck look like a skateboard ?
![]() Here is the best tire / speed /rpm calculator I've found yet , https://www.reillymotorsports.com/sp...alculator.html ![]()
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
![]() ![]() Join Date: Apr 2022
Yep you can fit 10s on the back no problem. Had 15x10's on the rear of this 71 we built and flipped a couple years ago.
The Twins: 1968 C10 SWB - Blue 327/5 Speed 1968 Camaro SS/RS - Blue 327/4speed C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278 The "Others" 1933 Ford Pickup (Camaro in disguise) 2017 Camaro SS Life long Chevy guy |
One of the First
![]() Join Date: Jan 2000
According to what brand of wheels, I've seen 15" MAG rims make contact with top of front brake caliper. Also, if you use inside stick on weights for wheel balance, they could get knocked off by top of brake caliper too.
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) Last edited by D.PASSMORE; 04-23-2022 at 10:13 AM. |
Do you happen to remember the backspacing ? That is a beautiful truck
I have a 69’ with the narrower axle, 10” will tuck. 4.5 BS.
1969 Chevy C10 SWB 350/400 4"-6" drop on steelies 53' Chevy 3100 5 window http://67-72chevytrucks.com/vboard/s...d.php?t=660793 http://67-72chevytrucks.com/vboard/s...d.php?t=771679 Last edited by Sim6; 04-22-2022 at 03:56 PM. |
1969 Chevy C10 SWB 350/400 4"-6" drop on steelies 53' Chevy 3100 5 window http://67-72chevytrucks.com/vboard/s...d.php?t=660793 http://67-72chevytrucks.com/vboard/s...d.php?t=771679 |
3.5" is what come to my mind, but I cant recall as this was 3 years ago and didnt have the truck much longer after mounting them.
