Old 12-31-2003, 03:32 PM   #1
roy
are 1967-1972 bodys all the same?
i have a 1972 chev 4x4 lwb rolling chassis. will 1967-1972 truck body styles bolt right up to existing body mount brackets on frame? will a 2wd body work?
roy is offline   Reply With Quote
Old 12-31-2003, 03:35 PM   #2
dinnut
dinnut's Avatar
for the 67 and 68 front clip.... you have to have the complete clip... ie radiator support hood grill and fenders for it to work. cabs are same except for the high hump and low hump. you might need to look into that. and beds are all mount the same. only difference in beds is that 67 had no marker lights...
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 12-31-2003, 03:39 PM   #3
Oborny71
Oborny71's Avatar
yes, it should work. 1/2 , 3/4 , 1 ton bodys are all the same. The 67-68 have different fenders and hood. but i believe the body mounts should all be the same, 2wd or 4wd.
67 Chevy SWB - goal of a 1,000 hp weekend cruiser
Oborny71 is offline   Reply With Quote
Old 12-31-2003, 04:38 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Roy, you have a 4x4 so you need a high hump cab. The floor will hit the transfer case otherwise.
Old 12-31-2003, 06:55 PM   #5
krue
Designated A-hole!
krue's Avatar
You can cut the low hump out of a low hump cab and bolt a high hump into it.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 12-31-2003, 08:26 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The body mounts are not all the same...the 1/2 ton 2 wheel drive has one style, all others have the other style.
Old 12-31-2003, 09:48 PM   #7
sdredneck
The Crazy Kracka
The Cabs are the same except that the 2wd Small Bloack trucks have the low hump. The Big block trucks regardless of 2wd or 4wd have the high hump. All 4wd trucks have the large hump. The low hump is non removable from what I hear. Both my blazer and 68 gmc 3/4 ton with 396 have the large humps. I think the difference is 2 inches high versus 4 inches high.
Sdredneck
My goal in life is to be as good of a person as my dog already thinks I am.
68 GMC LWB 396 BBC Camper Special
72 Chevy Blazer 4x4 with 406 SBC
73 Dodge Dart Sport with 340
sdredneck is offline   Reply With Quote
Old 12-31-2003, 10:25 PM   #8
krue
Designated A-hole!
krue's Avatar
Nothing is nonremovable with the right tools.
www.daveramsey.com
