12-31-2003, 03:39 PM | #1 |
pinion nut size
what size socket do i need to remove the pinion nut on a 3/4 ton rear end? my 1 1/2" socket dosen't fit. looks to be a weird size.
12-31-2003, 06:20 PM | #2 |
Mike
Mine took a 1- 5/16th.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
12-31-2003, 06:20 PM | #3 |
1 3/8 for the dana. Had to buy one of those myself in 3/4 inch drive. There tight... I was after the power lok and gears and the yard guys turned the truck over for me as I couldn't get the leverage needed under the truck to break the pinion nut loose. Dont worry the truck was worked over before they flipped it.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
12-31-2003, 06:41 PM | #4 |
What about a 12 bolt. I have every socket execpt that one. A 30mm will all most work.
