Got Horsepower?
bondo on wet truck
my truck got snowed on and I was wondering that if i dry it off with a towel and wait for it to warm up in the shop if it will be okay to apply filler on it. How long should i wait after applying and sanding the filler to primer it and if i put etch primer and then regular primer on it will it be sealed enough to keep water from soaking into it?
2001 Dodge 2500 Cummins, 4 inch lift, 35" Toyo MT's on Ultra wheels, P-Pump Conversion, AFE intake, Fass, 5 inch exhaust, Pyro,Boost,and Fuel pressure guages, and a whole bunch of other stuff "The Money Pit" SOLD-71 Chevy C10 long bed- 2/4 drop-- 350,th400, Edelbrock performer RPM intake,Edelbrock 600 CFM carb,Crower 240 cam,port and polish,Dynomax headers,HEI ignition,dual 2.5 inch exhaust with Flowmaster 50 series mufflers |
![]() Join Date: Apr 2003
I always wash the area that i'm going to fill, and then wipe it down with paint thinner. This is just a little peace of mind for me .
1969 K10 Custom 10 1997 Z71 2006 Volkswagen Jetta TDI 2006 King Ranch 1980 Wife |
Careful, they attack...
No amount of primer will not let water seep in eventually. Primer is very porous, that allows the paint to stick to it. It will be ok for a little while, but not for ever. I wouldn't let it go outside til it was at least 24 hrs old. That will let the primer set up really well.
Got Horsepower?
what should i do to seal it because i'm not planning to paint it until summer.
I am a Referee of life.
Spray over the primer with Krylon.Coat it well enough to keep it sealed.You will probably be doing some finish sanding before paint anyway right?
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
