Blue 67
Need help to ID this PS gear box
Hello:
I picked up this PS gear, pump, pitman arm and brackets long time ago (I am talking 10 years and more ago!) from local yard and I don't remember what model year chevy truck it was, 67-72 or next gen models. Based on what I have researched it has to be 1970s. I am about to finally convert to PS and I need a pitman arm and the nut which holds the pitman arm to the gear box. The nut on my current manual box seems to be the same size but it just doesn't start to thread on the shaft, so I am wondering if the nuts are different size. The casting on the box is 7802644, and the numbers on the 4 bolt cap are 7812145 and 018 71. Thanks for the help
1953 GMC 3/4 ton: current project 1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake 1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!! 1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive 1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project 2005 Silverado 2500, 4x4 Duramax, original owner |
The Older Generation
Re: Need help to ID this PS gear box
2WD or 4WD? Looks like those numbers cover a lot of different years and models. - The 018 71 may be the date, 18th day of '71. See if this web site helps any. https://leepowersteering.com/pages/h...entify-gearbox LockDoc -
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 04-26-2022 at 12:22 AM. |
Blue 67
Thank you LockDoc.
I have seen that site. It is very useful but unfortunately doesn't get it close to certain model years. If that stamped number on the cover is production year, then I should have taken it from a 71 chevy truck. That helps a lot.
| Bookmarks |
