Old 12-31-2003, 04:35 PM   #1
Injected68LS1
Injected68LS1's Avatar
Who knows a way to set camber and caster with digital level??
Anyone? I'm wanting to setup my caster, camber, and toe by myself. I want to get it in the ball park. I'm sure I can get it pretty close. I at least need to do this so I can drive it to the alignment shop.
I have a very accurate digital level so I can use a bar across the wheel and set the level against it. Camber is straight forward but how do I set caster? I think I turn the wheel to a specific steering angle and then check the angle at the wheel just like with camber.
1968 Chev SWB with 1998 Corvette LS1
305hp and 320 ftlb to the wheels (stock engine!)
AEM EMS and wideband O2 sensors
Bowtie Overdrive's 700R4, stage 3
Baer 4 wheel discs and 20s
http://iciclelanding.com/aperture?album=2049&view=album
Injected68LS1 is offline   Reply With Quote
Old 12-31-2003, 04:39 PM   #2
Injected68LS1
I can also use a Longacre camber/caster guage too. It's instructions say to check caster with the wheels turned at 20 degrees.
Old 12-31-2003, 06:12 PM   #3
Frank_Zeller
Frank_Zeller's Avatar
see links for good reference info.
http://www.familycar.com/alignment.htm#Cam
http://www.vtr.org/maintain/diy-alignment.html
http://www.allpar.com/fix/alignment.html
http://carcraft.com/howto/48938/
http://www.quartermax.com/IHRA/Iss05.html
69 SWB C/10 5-6 drop 700R4
69 Firebird Convert 455 4 spd
70 Torino GT Convert
Austin-Texas
Frank_Zeller is offline   Reply With Quote
Old 12-31-2003, 06:42 PM   #4
Rooster's 67
Rooster's 67's Avatar
your gonna need bearing plates with an angle gauge on them to do angle sweeps to set caster, and you need a gauge that will read off of the rim or hub to get accurate readings
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
Old 12-31-2003, 08:17 PM   #5
Injected68LS1
thanks guys.
Old 01-01-2004, 01:40 PM   #6
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
if you are just tring to get it close, so you can get to an alignment shop, just set the camber with the level, as close to level as you can, and then just adjust the toe with a tape measure, set it the same front and rear. don't worry about caster, you wont be able to set it correctly w/o an alignment machine.
if you set the camber and toe at zero, you should be ok driving to an alignment shop.
tommie is offline   Reply With Quote
Old 01-05-2004, 12:23 PM   #7
Frank_Zeller
A large plastic bags folded over works in place of a bearing plate.
Austin-Texas
Old 01-05-2004, 02:35 PM   #8
Slammed67
Progress = 0%
Slammed67's Avatar
This is obvious, but make sure your truck is sitting on a perfectly level surface before you do anything.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 01-05-2004, 03:35 PM   #9
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
If I may add. make sure the truck is level front to back and side to side. Also make sure tire pressure is the same all the way around.
67Fleetsidedream is offline   Reply With Quote
