Good afternoon.
I would like to build a tilting bed floor for my '67 C10 SWB. I am using oak barnwood so am hoping the frame itself can be made out of 1" square tube or so. My plan is to use a set of spare Ringbrothers billet trunk hinges and basically lift up the center boards that lie between the wheel tubs. I will have to notch and box where cut in the bedwood cross braces to clear the tilting frame which is not a big deal. This will give me access to my Boyd tank, suspension, and taillight fuel filler setup. I will also need to latch this down somehow. I am open to making my own or buying a kit to do this if it's what I'm after. Has anyone on here done anything similar, and can you offer any pictures, comments, or advice if so? I think I will have to hold the stainless bed strips to both outside edges of the tilted bed portion, so basically the strips lay back down in the slots and look unnoticeable when folded down. It should look clean this way and surely I can come up with a way to hold the boards from the bottom as well. Thanks in advance, I haven't had much luck finding much otherwise. |
Re: Tilting bed floor?
The hinged floor is fairly common in the full custom truck scene. It's done to allow easier access to battery's & air suspension parts mounted under raised bed floors. Multiple different ways to go about it but the basic frame layout you described is how to approach it.
Sorry, I don't have any saved images to share though.
#3 | |
That's my goal as well. I would like easier access to my battery, coilovers, and fuel system. I'll do some more searching and see if I can come up with anything. |
![]() Join Date: Apr 2008
Here is a possibility for you.
http://67-72chevytrucks.com/vboard/s...d.php?t=754408 Or this one http://67-72chevytrucks.com/vboard/s...d.php?t=684417 Or this one http://67-72chevytrucks.com/vboard/s...449548&page=36
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 Last edited by Mike Bradbury; 04-28-2022 at 10:12 AM. |
