Old 04-27-2022, 03:38 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
The transmission control pointer fiber optic cable's bulb plugs into?
I took a note the cable's peanut bulb plugs in near the speedo. cable, but it doesn't say where exactly. I don't think it matters really, being it's a light for any spot. I'd say #4. Just looking for verification.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 04-27-2022, 06:30 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: The transmission control pointer fiber optic cable's bulb plugs into?
Originally Posted by 71CHEVYSHORTBED402 View Post
I took a note the cable's peanut bulb plugs in near the speedo. cable, but it doesn't show where exactly. Looking at things, I'd say it takes the hole where #1 is marked, verification appreciated. Thank you
On the other side. Hole #4
LockDoc
Leon
Old 04-27-2022, 07:48 PM   #3
71CHEVYSHORTBED402
LockDoc
Right Doc, I had just edited that post. After installing everything else #4 made the most sense.
Thanks again.
BTW, I thought I'd gotten an extra key set from you, found it today
Old 04-28-2022, 12:07 AM   #4
LockDoc
LockDoc's Avatar
Thanks again.
Don't lose them, like everything else they are getting harder to get.
LockDoc
Leon
