RHCP afficianado
quick help needed
I'm working on replacing the timing cover on my truck and have run into a problem. The bolt that holds on the lower pully and the balancer wont come off. We have tried to take it off with the truck in every gear but it still wont come off. Any ideas on how to get it off? All it does is turn the engine no matter what gear.
~Ryan~ 89 S-10 Blazer with a 4.3L 96 Ford Crown Vic P71 4.6L V8. This car rocks. ![]() Here are some links to some good music. Jack Johnson Donavon Frankenreiter |
Slots go on anything!
can you wedge a pry bar through one of the holes n the balancer and against the block to keep the engine from turning? That should work. BTW, if it is turning that easy, you may have other problems. Do you have the plugs out? If so, put them back in.
1974 Jimmy- 5.3/4L80e/NP241 |
You're supposed to loosen that before you take all the belts off. Try this, put the pulley back on the balancer and hold it with a pipe wrench. That's what I did when I was in your predicament.
Gary -1986 SWB: lowered 4/6, SOLD!!! -Best 1/4 mile: 14.51 @ 91.01 MPH -2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!! -2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels |
RHCP afficianado
the plugs are in. What if we were to put a rope through one of the holes and hold the balancer?
You get what you pay for
![]() Join Date: Dec 1999
Best way is with an impact wrench. But if you don't have access to one, stick a jack handle or similar through the balancer to stop it from turning. You can also so the same at the flexplate, but I'm guessing you are not under the truck.
Mike 1985 Chevy C-10 |
I've never done this but I heard it works. Put a socket on it with a long handle & wedge the handle against something immovable (frame, etc.). Remove the coil wire & bump the starter just a little bit.
