is it possible to use a 68 front clip with 71 frame & cab?
I know this has been covered but I couldn’t find anything from a search.
I would like to use the front clip and bucket seat from a 68 parts truck with on my 71 project truck. Will the front clip line up properly with a 71 cab and 71 frame? Will the bucket seats install into a 71 cab that had a bench seat? Will I need to modify bolt holes, etc... Thanks Ian |
Designated A-hole!
I am pretty sure you will have to make new holes for the inside mounts on the seats. The front clip will work but I think you need the 68 core support, or maybe it's the hood latch. I know you can take the entire clip and put it on your frame, you just can't mix and match between pieces of the front clips. I hope that makes sense.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
yeah you need the core suppotr because if you dont change it the headlights will be in the wrong spot...
70 longbed 496/th400/Ford 9" |
