04-29-2022, 05:38 PM | #1 |
Tail light assembly
Can someone help me out with what I’m missing? The new housing I got hit these tabs shown in the picture below and the bolts are about a half inch from coming tight. Can someone post a picture of their tail light assembly removed? It appears there should be something between the reverse light and tail light I’m missing as well?
Thank you |
04-29-2022, 06:54 PM | #2 |
Re: Tail light assembly
I’ve answered part of my question. Any advise on how to make a correct housing will be appreciated. Try to find a junker to hack that cross piece off I’m missing and weld to mine maybe?
Posted via Mobile Device |
04-30-2022, 07:03 PM | #3 | |
The Older Generation
Let me take a look in the morning if it isn't raining cats & dogs..... I have a rear corner I need to replace but I can't remember where I was going to cut it. Either way I should have one of those pieces left over. LockDoc
05-01-2022, 08:59 PM | #4 |
Thank you. I might have a donor pickup I’m hopefully goin to be able to do some robbing off of
05-02-2022, 11:47 AM | #5 |
You are missing the bar that goes between the stop light lens and the reverse lens. For an easy fix, mount your reverse light and stop light and then use the factory trim piece around them so you won't need that bar.
You will need to remove those tabs or just bend them out of the way because that lens housing shown in your picture needs to sit 1/2" deeper. If you use the factory trim rings like I suggested, you will need to drill it's mounting holes in the body, but if it was me, I would glue them on with windshield urethane or construction adhesive. I didn't want to use those trim rings, but I messed up and forgot to fill the mounting holes when doing the body work so now I'm stuck with them. FWIW, when these truck came from the factory with those trim rings, they also had 2 pieces of trim that ran along the width of the tailgate. Last edited by hemi43; 05-02-2022 at 11:57 AM. |
