Old 05-01-2022, 07:17 PM   #1
MDFarms
What Color for Tranny
Just curious what people are using for paint on their transmissions? Want to go with a similar color tone as original that will look good glossy. I sanded it down with DA sander now ready for paint.
Any thoughts?
MDFarms is offline   Reply With Quote
Old 05-01-2022, 07:24 PM   #2
dagnabbitt
dagnabbitt's Avatar
Re: What Color for Tranny
Seems like most people use argent. I have also seen red.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 05-01-2022, 07:43 PM   #3
MDFarms
Thata what I was thinking.
Old 05-01-2022, 08:29 PM   #4
jimijam00
No paint. Scotchbrite wheel, cotton wheel, and wheel polish.
jimijam00 is offline   Reply With Quote
Old 05-01-2022, 08:31 PM   #5
sick472
sick472's Avatar
I don't paint the transmissions. There's not any advantage unless it just for personal preference and the desire to color coordinate. Some of the exterior parts are regular steel and I paint those, but the aluminum, I just clean it and sand it to my taste.
Transmissions don't get that hot, but engine enamel is an excellent paint for transmissions. It will cost a few more dollars than non-high temp paint, but your only talking a can or two to do the whole transmission. Make sure you don't sand it too fine. Aluminum can shed paint easier than steel and should have some rough surface for the paint to adhere to. If your going for real smooth on the aluminum, look for a self etching primer first, then a light sanding, then the paint.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 05-02-2022, 02:14 AM   #6
Accelo
Accelo's Avatar
I powered coated my transmission gray, which may be close to argent?
However, I have also used what's called almost chrome powder coating without the clear.
Looks just like new aluminum and cleans up easily.
Plugging the holes, before coating the case, was the hardest part.
I am including a picture of a hood hinge I coated with the almost chrome powder.
Accelo is offline   Reply With Quote
Old 05-02-2022, 09:57 AM   #7
I use tranny color
