Old 05-04-2022, 04:08 PM   #1
earl1951
earl1951's Avatar
stock deluxe wheel to Flaming river column
does anyone remember the the post about making the horn work with the FR column.it was very specific about the wire from the column to the steering wheel.i've looked for hours and can't find it.thanks
earl1951 is offline   Reply With Quote
Old 05-05-2022, 09:59 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: stock deluxe wheel to Flaming river column
The only wire like that is the canceling cam wire, I think this is the thread with instruction link from Flaming River - http://67-72chevytrucks.com/vboard/s...d.php?t=441198
Instruction link - http://www.flamingriver.com/download...pdf/tiltcolumn
Old 05-05-2022, 02:57 PM   #3
earl1951
earl1951's Avatar
thanks, I've got all that,just need to figure out the factory horn stuff to work with the Flaming River column
Old 05-05-2022, 04:35 PM   #4
The Rocknrod
Moderator
According to the link above, pin location G is a black wire. It goes to the horn relay. Are using a stock wiring system or aftermarket? If you have a stock crescent column wire terminal on the truck, you can buy an adapter (AAW has them) if you don't wish to re-term that side.
