Old 05-06-2022, 12:27 AM   #1
72SB
Brake Line fitting size?
72 manual disc/drum
what is the thread/pitch of the front & rear brake line fittings that goes to distribution block?
72SB is offline   Reply With Quote
Old 05-07-2022, 06:19 PM   #2
HO455
HO455's Avatar
Re: Brake Line fitting size?
Please post a picture. Otherwise we are just guessing.
RIP Bob Parks.
Old 05-07-2022, 11:44 PM   #3
72SB
The front & Rear brake line on proportioning valve (yellow arrow), what size are those line fittings?
Old 05-07-2022, 11:48 PM   #4
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
The one on the left of the pic is 3/16" tube, so should be a 3/8" nut. The other line is 1/4", which I believe has a 7/16" nut. Are you looking to buy line wrenches? I have some you can use. You're only a few miles from me.
~Steven
Simi Valley, CA
Old 05-07-2022, 11:55 PM   #5
72SB
I want to know the thread size to see if I need adapters for the new MC/Booster/PV I am installing
front 3/16-18?...or?
rear 7/16-24?
Old 05-08-2022, 12:00 AM   #6
72SB
I have flare wrenches......and this set that is the Snap On clone, only $200 less
Old 05-08-2022, 12:10 AM   #7
Steeveedee
Steeveedee's Avatar
I don't remember the thread pitch, but a b-nut is a b-nut. They only have one pitch. I think I have some in my parts stash. I'll take a look.
ETA- both have 24 pitch threads.
~Steven
Simi Valley, CA
Old 05-09-2022, 11:14 AM   #8
72SB
No one knows the thread size & pitch of the stock front & rear brake lines connection to proportioning valve??
Using the CPP disc/drum proportioning valve. In other swaps I have done on other cars I needed a few adapters to connect existing brake lines to aftermarket PV, was hoping to find out before swap so I have them.
Old 05-09-2022, 11:25 AM   #9
pjmoreland
pjmoreland's Avatar
The CPP PVK installation instructions list the sizes of the ports on the CPP combination valve.
pjmoreland is offline   Reply With Quote
Old 05-09-2022, 11:40 AM   #10
conoco
conoco's Avatar
I just completed this job a couple days ago on my 1972 k20. I put a new proportional valve on and converted my rear drum to disc. However, the same fitting sized were used. I made about 5 trips to napa because I was trying to find the right fittings.
You will need
3/8-24 inverted flare nut (7/16th wrench) for the front brakes
9/16-18 inverted flare nut for the rear brakes
1/2-20 and 7/16-24 connection for the master cylinder
Mine was all stock that I replaced. Hope this helps.
1972/Sierra Grande k2500 / 383 / th350 with Gear Vendors / 4.11 / 4" lift with 35s / Eaton Rear Axle
conoco is offline   Reply With Quote
Old 05-10-2022, 10:04 AM   #11
72SB
Thanks guys, I do have the 411 info in the CPP kit....are the stock lines the same size fitting as the CPP kit?
