Front crossmember shifting
Sounds like a suspension issue, but when I looked under the truck I saw that the front cross member was moving. Like if the rivets are loose. How do I fix this?
Posted via Mobile Device |
![]() Join Date: Sep 2007
Re: Front crossmember shifting
pound out the rivits and run some grade 8 bolts in it
1967custom |
![]() Join Date: Dec 1999
Front cross member is bolted in. There are some rivets holding the angled pieces the upper control arm bolts to...
Who Changed This?
![]() Join Date: Jan 2013
If you have access to the repair manuals, they will give you the distances to trammel points. Measure them and by some trick or another, probably a come-along, pull the crossmember into square and tighten the bolts. You can have a frame shop do it, but with the right knowledge and equipment, you may be able to do it. If it has been shifting around, I'd recommend replacing the bolts, at a minimum. They've gotten pounded with the shifting around and could break downstream.
Thanks for the replies
