Old 05-06-2022, 09:34 PM   #1
forestb
forestb's Avatar
Under hood heat Insulation
Any body do any heat insulation on the underside of your hood? I have seen one in a catalog that is around $1000 which seems really expensive but it is set up specifically for our trucks. I have seen people use a bed liner type spray on material. Any suggestions?
forestb is offline   Reply With Quote
Old 05-06-2022, 09:51 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Under hood heat Insulation
Bed liner spray would be good for rust, but not much good for insulation. Which way do you want the heat not to flow?
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 05-06-2022, 10:33 PM   #3
forestb
forestb's Avatar
I am trying to keep engine heat from effecting the exterior paint on the hood. What I saw might have just looked like bed liner.
Old 05-06-2022, 10:53 PM   #4
AcampoDave
AcampoDave's Avatar
I did it. First with strips of Kilmat then with Dynamat under hood liner. It works no doubt about it. I suppose it would be fine with the underhood liner alone if you were only worried about heat, but the Kilmat strips really made that hood feel solid. When I open my hood after a summer drive, even after its been shut off for several minutes, a gyser of heat rolls up out of there. Its quieter. Driving down the road too. Here's a pic I took halfway thru. It takes two boxes of the underhood liner for full coverage.
Edit: Here's the thread from when I did it http://67-72chevytrucks.com/vboard/s...d.php?t=808418 I was going for noise reduction but it definitely contains the heat too
AcampoDave is offline   Reply With Quote
Old 05-06-2022, 11:53 PM   #5
forestb
forestb's Avatar
I saw the dynamat stuff on there website. I am not sure if I like the shiny finish. Do you remember where you purchased it from? I saw some black stuff made by Boommat that is meant for under the hood that classic industries sells. In my search I also came across lizard skin spray on insulation.
Old 05-06-2022, 11:56 PM   #6
forestb
forestb's Avatar
Here’s a link to the one I saw at classic industries
https://www.classicindustries.com/pr.../de050129.html
Old 05-07-2022, 01:05 AM   #7
AcampoDave
AcampoDave's Avatar
I got all the stuff for that job including a little roller for the Kilmat on Amazon. I might recall the Dynamat hood liner being available in black too...i think. In any case you have a bit more choices since your mainly concerned with blocking heat, as oppose to a combination of heat AND noise but Dynamat products are indeed high quality. One drawback though is that it is some sticky stuff so there are no second chances on sticking it in place
Old 05-07-2022, 08:03 AM   #8
The Rocknrod
Moderator
The Rocknrod's Avatar
Then there's these: https://www.lmctruck.com/1960-66-che...nsulation-kits
But I think these are the coolest - https://www.quietride.com/acoustihood.html
Catalog - https://www.quietride.com/web/viewer...ood_covers.pdf
Old 05-07-2022, 10:26 AM   #9
forestb
forestb's Avatar
Yah I have used Dynamat under my carpet and it works vary well.
Old 05-07-2022, 10:35 AM   #10
forestb
forestb's Avatar
The LMC on is the on I saw before. I don’t know why I thought it was so expensive. The quiet ride one is what I am looking for I think. I am always a little hesitant when it comes to LMC. I always feel like they are selling a lesser product.
Old 05-09-2022, 10:39 AM   #11
verdell
verdell's Avatar
Dave,
Did this add quite a bit of weight to the hood in terms of the springs keeping it lifted when opening the hood?
verdell is offline   Reply With Quote
Old 05-09-2022, 07:20 PM   #12
AcampoDave
AcampoDave's Avatar
Full open is no problem but trying to keep it at mid-level is a balancing act.
Old 11-26-2022, 02:02 AM   #13
forestb
forestb's Avatar
Does anyone know if LMC is selling the quiet ride product. It seams very similar but the prices are different. I called LMC to ask but the lady I talked to sounded like she could not access that information.
