New to me 87 c10. Some questions
Hi all,
After of months of searching, I've settled on this clean 86 c10 that is an original Texas truck 1- the 305 has been changed over to a carbed vortec 350 with edelbrock carb. I have the original carb, but I'm unsure if the factory wiring and ecm are functional. Can the electronic q jet be run with out the electronics? I prefer the performance and mpg of the qjet. Associated with this question, the factory cruise is there, but unhooked. Does this operate through the computer as well? Or can I supply vacuum to it and let it do its thing? It has a bunch of wires running to it. 2-does the th350c transmission lockup function work without the ecm on these pickups? Not sure if it's working or not yet. 3- I'm looking at led headlights for it as there are alot of deer in my area, and I drive alot of miles. Most of the LED replacements have a high and low beam built into each bulb. I'm concerned that won't work for thus rig since 2 lights come on for low, and 4 for high. What have you guys had good luck with? 4- paint. It's good, zero rust. But the passenger door is starting to fade faster than the rest of the body. When I rub on it a little I get color on my hand. Should I cut/ buff and wax? Or just wax? Or do nothing at all? Thanks! I'm sure I'll have more questions to come Last edited by Dieselfume; 05-07-2022 at 05:16 PM. Reason: Truck is an 86 c10, not 87 |
| Bookmarks |
