Old 05-11-2022, 11:18 AM   #1
weim55
Correct exhaust manifolds 283/327 for 64 to 66 ??
Correct exhaust manifolds for 283/327 for 64 to 66? Are the manifolds center dump with no angle on the left and right? Are the manifold essentially the same except for the alternator mount bracket on the left side? I have a pair of right side center dump ram horn manifolds from a 63 impala that I believe will work on the truck as long as I’m not using an alternator bracket on the left side? My truck has a long waterpump so I don’t need the bracket mount on the exhaust manifold.
Steve weim55 Colorado
weim55 is offline   Reply With Quote
Old 05-11-2022, 02:20 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Correct exhaust manifolds 283/327 for 64 to 66 ??
Getting the right manifolds center dump or not doesn't matter much since your water pump isn't correct anyway, so use what you need to use in order to get it running.
Old 05-11-2022, 02:24 PM   #3
MikeN
MikeN's Avatar
I have rams horn manifolds on my 64. They point straight down (guess that is what you are calling center dump?) and they work just fine.
MikeN is offline   Reply With Quote
Old 05-11-2022, 02:28 PM   #4
cwcarpenter98
cwcarpenter98's Avatar
The correct manifolds will dump straight down at the center for your truck. Since you don't need to use the alternator bracket, you can use both manifolds from the 63 Impala that you have if they both dump straight down
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 350, Saginaw 4 speed
Old 05-11-2022, 02:46 PM   #5
weim55
I plan on using a factory style Y pipe hence The importance of knowing the dump angle to match. I think you guys answered the question, thanks for the help!
Old 05-11-2022, 03:53 PM   #6
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Yep, my 66 has the y-pipe and has the center dump straight down manifolds.
66 C20 Service Truck:
