Carpe manana
![]() ![]() Join Date: Dec 2010
Wood stove in garage/shop?
Anyone use a wood burning stove in their shop or garage? Bad idea? The thought has crossed my mind ahead of breaking ground here for a detached garage but as a supplement not primary heat source.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland
Re: Wood stove in garage/shop?
Check your local regulations. Some places are getting pretty negative toward wood burning anything.
Do you have a source of free/low cost firewood? Do you have the tools and equipment to turn trees into firewood? Do you have a place to store the wood? Are you willing to spend the time dealing with firewood? I have a wood stove in my house that I use when the temps get below freezing for an extended time. It puts out too much heat for use in warmer temps. Don't know that for occasional use, it would be worth the space in the shop for a wood stove. There is a significant lag between lighting the fire and the stove getting warm enough to start heating the place. My house came with the wood stove so I use it. Current thinking on my shop is installing a combo heat/AC unit that uses propane for the heat. I did add extra insulation to the shop first. I like the idea of when I want to do shop stuff of being able to walk out to the shop, flip a switch and come back 15~30 minutes later and the shop is well on the way to being warm or cool depending on season. |
Carpe manana
Thanks. More wood here than I can shake a stick at. I wouldn’t make use of a wood stove as a primary heat source though. More so to enjoy while tinkering on projects or just kicking back.
I would go for it, a woodstove will make quick work at knocking out the chill in a detached garage, then make it toasty...miss having my woodstove in the house, I did bring it with me to my new house that has propane heat, but with these insane fuel prices I may be doing an install soon...
![]() Join Date: Jul 2001
I have wood heat in my detached 35x50 shop and altho don't use it regularly it does a good job for heating. No gas lines near the shop and electric heat or propane is just too pricey. Takes a bit to warm up true but after I get it started in late fall or winter weather I generally go back in the house for another cup of coffee. Actually is a barrel stove made from two 55 gallon barrels, one stacked on the other for added heat collection. Use an oscillating pedestal fan to move the heated air thru the shop. Have two acres with a lot of trees that always need trimming. Also burn scrap lumber when does not have any paint or oil on it. Always a source of wood fuel so cost was minimal except for initial barrel stove kit and flue pipe.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
Carpe manana
Thanks guys I’ll look at placing a flue outlet at least.
I had one. Was too much trouble for me. Took up too much space
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis 1964 GMC K10 383cu in/sm465/twin stick np205 1965 Chevy C60 1990 Chevy Bus 8.2l fuel pincher 8800 miles 1993 Ford F350 crewcab 7.3idi nonturbo ZF5 Transmission Running on WMO |
![]() Join Date: Jul 2015
I'd do it, with the availability of wood you have it would be worth it. I like your idea of just having it for tinkering and hanging out, I love me a wood fire, especially on those cold days where you just want piddle and watch the snow with an adult beverage. Installing a flue is definitely a must, if you don't do wood maybe look into a DIY waste oil heater. We have propane heat as the primary in our house and good lord was that pricey this winter. There is a flue that needs relining in the basement and I think that's going to be on the docket this summer to fix up and run wood this winter and use propane to supplement instead of primary.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
Just be careful with any open flame, nobody ever plans on leakin/spilling fuel on the floor but it'll happen sooner or later and it spreads quickly.
81 camaro 355 4/spd 342 posi my first love .67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
Wood stoves are great. Just be careful what you store in the garage. Maybe get a small shed for the winter to put your gas cans and other crap in that is flammable.
Also. Put the stove up on a platform. At least 12” flammable gasses are heavier than air.
Please be patient. I’m a ford guy. This is my 1st Chevy. Previous cars: 1973 mustang convertible 2003 mustang Mach 1 Now building resto mod 68 C10 step |
Carpe manana
Thanks for the helpful input guys.
![]() Join Date: Mar 2003
If your garage is sealed like mine then it would be a big NO. Personally I have too many flammables in my shop. Gas, Brake clean, carb cleaner, solvent tank..you get the idea. I do however have an overhead propane heater
#13 |
![]() ![]() Join Date: Oct 2014
And how do you like it? What size is your shop? How much propane/how big of a propane tank do you have? I want to get something for later this year when winter rolls around so that I can go out there and mess around. My shop is 60'x40'. Also, this may sound like a stupid question, I thought i read where propane heaters can cause things to rust. Is this true, or just bogus info?
#14 |
Carpe manana
Will use a ceiling mounted propane Reznor unit to heat the garage and a 8’ diameter 220v ceiling fan to circulate the air. Floor heat would be great but too costly.
#15 |
![]() Join Date: Apr 2013
I use a coal stoker stove and love it. I have a thermostat on it and keeps it within 4 degrees. Not bad for 2400 sq ft. I assume your wood stove will be just as nice. Insurance company said they were ok with it, but not wood.
The coal stove has much better constant heat and much cheaper to run than my Modine Hot Dawg.
72 Cheyenne Super C10 SWB 2001 Silverado 1500HD Crew 2011 Silverado 2500HD Crew Duramax (Hers) |
#16 | |
#17 | |
#18 |
my licensed commercial repair garage has had secondary heat wood stove for 50+ years, I have painted our wreckers in the shop with the stove going with no problems, (not totally recommended) but common sense is key with flammables,
#19 |
Carpe manana
Good details. Thanks for posting.
#20 |
![]() Join Date: Dec 1999
Any gas heating appliance without a sealed combustion chamber is no different than using the wood burning stove. Only difference is wood is the fuel instead of gas. The flame or combustion process is still using the space for combustion air and the flame is exposed to the space being used.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
#21 |
Everybody has a wood stove in the shop up here in Maine. If I were richer I would prefer an oil furnace.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
#22 |
I used a pellet stove at my garage at my rental. I put it on a metal dolly to move it around . I cut a 4 inch hole with a hole saw into the steel overhead door . Wheel the stove over to the door stick the flue out and let her rip . At shutdown it runs till it's cold and I would move it back to where I stored it. My daughter is using the stove now in her house
| Bookmarks |
