Axle Swap Heavy Half
So my dad swapped out the rear axle in the family 59 with a 1980ish Heavy Half rear axle to get a higher gear ratio.
It fit very well and he swapped out the 5 bolt axles with 4x4 6 bolt axles to keep the original 6 bolt rims. (It's only about an 1 1/2" wider than the original.) Can anyone tell me what the 6 bolt axles would be from? I need a speedy sleeve and want to get the right one.
So when is this "Old enough to know better" supposed to kick in? My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989 |
![]() Join Date: Mar 2003
Re: Axle Swap Heavy Half
How many bolts on the rear diff cover?
I don't think there any variations in size with the 12b axle-----not like the later model 10b or 14b. Try an application like a 75 K10. OR you can pull the rear diff cover and get a date off of the ring gear
Anything 73-80 truck or Blazer 4x4 would be my starting reference point for a parts search.
That family 59 is a neat truck!
| Bookmarks |
