05-18-2022, 03:49 PM | #1 |
Side windows
I have had my local glass shop cut side windows for the 48 because I didn't want to use the steel framed windows. I got the thinner window channel to accommodate the glass only.
The glass shop has cut the windows twice, and they still don't fit! Does anyone have a glass company who has cut side windows that fit? If you have, please PM me, as I'd like to talk to you about it. Thanks
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
05-18-2022, 10:03 PM | #2 |
Re: Side windows
Did you take the truck to them or are you having them guess when they cut the glass and you take it home?
05-19-2022, 08:57 AM | #3 |
Re: Side windows
I first took them the old side windows with the metal frames to "match". I took that cut glass home and it didn't fit. So, I made some measurements where they were short or long and took those back. The re-cut new ones and they don't fit. I've made new measurements where they are short, and on the top line of one of the windows, it has a "whoop" in it, as in not straight.
I like the owner, but I think he has used two different workers to cut the glass.
05-19-2022, 01:42 PM | #4 |
Re: Side windows
Glass is one of those few things that I just hate to do and leave to the pros. I have found that making patterns out of a sheet of 1/4 inch Masonite works pretty well for going different than absolutely original.
i figure to haul my truck 180 miles to a shop that will make tempered windows for the side glass for it and have them do the whole thing. Not cheap but unless the full service glass shop that I take my OT rigs will cut the glass and send it to be tempered that is probably my best choice. I[m going to have some pretty long door glass when I am done though.
05-19-2022, 08:27 PM | #5 |
Re: Side windows
Make a hardboard template, install it and make sure it works as you want it to.
Take that template to any glass shop
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
05-20-2022, 09:40 AM | #6 |
Re: Side windows
Thanks for the suggestion, Ogre. That makes sense.
05-20-2022, 10:05 AM | #7 |
Re: Side windows
use hardboard, melamine sheet or plexiglass the same thickness as the glass will be. make the pattern and get it to fit like you want the glass to fit, fully assembled in the rails etc and then crank the windows up and down to ensure it all works to your standards. when good, take it all apart and have the glass made to the new pattern. don't assume both doors will be exactly the same. you may need 2 patterns.
05-20-2022, 10:06 AM | #8 |
Re: Side windows
Again, I didn't think about the 2 doors being different, but I should have.
I see a trip to the hobby store in my future.
05-20-2022, 10:26 AM | #9 |
Re: Side windows
you might try a plastic shop for some cut off plexiglass or other plastic sheet sold by the pound as leftovers, or home depot for something the right thickness but also smooth both sides.
05-20-2022, 10:28 AM | #10 |
Re: Side windows
Home Depot is very close to me; I'll go there first. Thanks.
05-20-2022, 11:37 AM | #11 |
Re: Side windows
i thought home depot was close to everybody
i moved to the boonies 25 yrs ago, the only hd was 10 miles away now i have 5 within those 10 miles and a lowes
05-23-2022, 11:31 AM | #12 | |
Re: Side windows
Bizzare! Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
05-31-2022, 03:12 PM | #13 |
Re: Side windows
OK, rider's door is a little different than the driver's door. I've got one template built, and it moves up and down pretty good. I will do the driver's side as soon as the new Jigsaw gets here from Amazon. Yeah, I knocked my 30 year old Jigsaw off the work bench and broke it.
However, WHAT are you all using for screws to hold the window lift channel to the bottom of the window? I'm having no luck finding screws that fit inside the channel, with heads that don't interfere with the operation.
05-31-2022, 05:19 PM | #14 |
Re: Side windows
Your truck window may be different, for my 58 TRUK I cut the bottom off the old side glass window frame and glued in the new glass with butly windshield adhesive. It's held up for 12years of abuse
05-31-2022, 05:21 PM | #15 |
Re: Side windows
Ogre, thank you. Your template idea has really helped.
I'll keep the butyl in mind if I can't find some screws that will work.
06-02-2022, 12:33 PM | #16 |
Re: Side windows
Finally, one plexiglass window has been cut and sanded to fit. I put it in the window channel with some of the black sticky tape I got from the glass shop and have been rolling it up and down making sure it fits. I finally got it where it's good.
I got the new Jigsaw delivered yesterday, so this afternoon I'll start on the driver's side. Should be easier now that I know a little more about what I'm doing. Thank you all for the help.
06-02-2022, 12:37 PM | #17 |
Re: Side windows
If you have access to a stationary disc sander or belt sander that makes quick work of the fitting part of mock up.
06-02-2022, 12:41 PM | #18 |
Re: Side windows
Thanks Raven. I do but was worried about taking off too much with a slip up when holding that window.
I used the Jigsaw to do the rough cut, and then a 3" handheld belt sander to remove small amounts to "sneak up" on the correct size I needed. I put a pad under the plexi on the work bench, used a piece of angle iron and a couple of C clamps across the glass to hold it down, and then did one side at a time, very carefully, measuring, sanding and re-fitting until I got it where I liked it.
