Old 05-18-2022, 04:10 PM   #1
Kip7143
Truck is not running
Hi Guys!
I am hoping for some help with my 1981 Chev. Since I bought the truck it's been a little rough and tempermental but drivable for the most part. Now it's really not running. So here are some details.
The truck at this point is only running when throttle is held. As soon as I get off the throttle it chokes and dies. When it is running, its sputtering, almost like a misfire. Since I got the truck I knew a lot of the vacuum lines were old and cracked, so I recently replaced everything to see if that made a fix.
Still the truck isnt idling and will only run on throttle, with a good sputter. Does anyone have any idea where I should start? One thing, when I disconnect the vacuum from distributor it still runs very rough, but wont stall.
Second to all of this... I do not know how to time this truck. There doesn't seem to be a timing tab.. does anyone know how to time the straight six motors?
NOTE: the clip is from a 79, its not the factory clip on that truck
1981 Chev C10, straight 6 4.8l motor, Automatic. Pretty well all stock.
Kip7143 is offline   Reply With Quote
Old 05-19-2022, 08:04 AM   #2
sick472
sick472's Avatar
Re: Truck is not running
When you disconnect the vacuum line from the distributor, do you plug the line to keep that from being a vacuum leak?
Have you inspected the inside of the distributor cap for wear or contamination?
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 05-19-2022, 08:26 AM   #3
Kip7143
Yeah plugging the line yielded the same results. Im going to take the distributor apart today and check the EGR valve.
Old 05-19-2022, 08:33 AM   #4
geezer#99
geezer#99's Avatar
Do you have a pic of the engine bay?
Without the air cleaner on is best.
Old 05-19-2022, 09:16 AM   #5
Kip7143
Here you are
Old 05-19-2022, 10:32 AM   #6
geezer#99
geezer#99's Avatar
The timing tab is at 10 o’clock.
Pic in post #15 shows it’s location.
http://67-72chevytrucks.com/vboard/s...d.php?t=702366
Old 05-19-2022, 11:00 AM   #7
jayoldschool
Moderator
Good info so far! Do you have a photo of the idle speed screw and throttle linkage?
jayoldschool is offline   Reply With Quote
Old 05-19-2022, 11:33 AM   #8
Dead Parrot
If you have vacuum assist power brakes, a leaky booster can leak enough air to cause idle problems while still providing enough boost to make the brakes seem normal.
If the transmission has a vacuum shift modulator, make sure those vacuum hoses are good.
The vacuum pot on the distributor can leak as well. Might explain why the truck keeps running with the vacuum pot disconnected and the line plugged.
Dead Parrot is offline   Reply With Quote
Old 05-19-2022, 05:08 PM   #9
Kip7143
Hi all, thanks for the replies.
I did some work today and heres what I've come up with. I changed the majority of the distributor parts and found some heavily warn components. I will post pictures below.
I made the mistake of playing with a few things at one time, so I don't know what made the biggest impact. Reading my 1981 Chevy repair manual, in the diag section I found some info that an faulty EGR will present similar symptoms that I am seeing now, rough idle, stalling, sputtering. So I removed the EGR and did a bench test, when I first depressed the diaphragm and covered the vacuum port it didnt move back, I thought "oh this is good". Then I let go and it remained in the same place and thought "oh this may not be good". I continued to move the diaphragm until it moved freely.
I then pulled all the spark plugs but they were all in good shape and gapped appropriately. So I didn't find anything wrong there.
I put everything back together and its running a lot better. It's starting much easier, running smoother. I'm thinking the combination of fresh destributor parts and freeing up the EGR is what's making it run better. I am thinking of changing the EGR regardless.
The only issue currently is I cant adjust idle. The idle screw doesnt seem to want to sit properly for hot or cold adjustments. Its idling in park at about 1100 and in drive at 800.
The only symptom still perssisting, which has really always been there, is a randon sputter or popping at when idling in park. Any suggestions or comments?
Old 05-19-2022, 05:34 PM   #10
truckin 79
I would check out a few spark plugs and see what they look like. They will tell you a lot, black they are rich, oily bad rings or seals and white and chalky could be lean. You could also get truck to idle and put hand over carb slightly, if it smooths out and RPM climbs it is running lean and possible vacuum leak, if it dies right away probably to rich. Just some simple checks also look for timing tab it might be covered in grease
79 Chevy 2wd BIG10 350 TH400
truckin 79 is offline   Reply With Quote
Old 05-19-2022, 05:35 PM   #11
geezer#99
geezer#99's Avatar
You need to check the timing.
Your high idle in drive and park can be from a lack of initial timing.
Did you check the vac pot on the distributor too?
Old 05-19-2022, 05:50 PM   #12
Kip7143
I did pull the plugs, they are white / chalky. Definitely a solid chance if a vacuum leak since most of the hoses were super old and original.
I think the timing tab was knocked off the truck or something. I’ve had others look and no one can find it in either the 10 or 2 position. I checked with a timing light today and cyl 1 is TDC around the 10 o’clock position.
Old 05-19-2022, 06:46 PM   #13
geezer#99
geezer#99's Avatar
You could make your own timing tab or adapt one like this.
You’d need to find true tdc using a piston stop.
https://www.holley.com/products/engi...ape/parts/4597
Old 06-11-2022, 04:11 PM   #14
Kip7143
Hi again,
Got the truck running and driving but it’s still dying at idle randomly. It’s definitely running rich, you can smell it and see the white on the plugs.
Now one thing I’m having trouble with is low idle. I took a photo of the idle screw and the 3 step piece it’s supposed to touch. When the choke turns off, the idle screw sits below the lowest level so I can’t adjust the idle speed. Anyone experience this? I’ll attach a couple of pictures for reference.
Old 06-12-2022, 07:46 AM   #15
Corts60
Just here to tinker
Corts60's Avatar
Having white plugs and a rich condition at the same time doesn’t really add up. Plugs should be black if you’re smelling rich fuel. It sounds like that carb needs to come off and be gone through. All these problems you’re reporting, you may just have a gummed up idle circuit or something like that. Also, are you sure that screw you took a picture of is not the fast idle screw? That is different from the regular idle adjustment.
And that screw is stripped bad. Maybe time for a whole new carb?
Old 06-12-2022, 12:02 PM   #16
Kip7143
Is there a different “idle speed screw” elsewhere? That’s the only one I can find.
Old 06-12-2022, 03:03 PM   #17
Pontiac1976
Pontiac1976's Avatar
It's normally near the base of the carb you should see only the head of the screw mostly
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 06-12-2022, 08:40 PM   #18
Kip7143
Could this be it? Doesn’t seem to make contact with the throttle?
Cool to see you’re in Ottawa! I have an old Pontiac too!
Old 06-12-2022, 08:49 PM   #19
Corts60
Just here to tinker
Corts60's Avatar
I’m not familiar with your style carburetor, but my guess is that screw in the background with a spring on it is the idle adjustment. The other one is definitely a fast idle adjustment or it wouldn’t be on a stepped cam like that.
Old 06-12-2022, 09:25 PM   #20
Kip7143
Okay thanks .. I’ll play around with it and see what I can get
Old 06-12-2022, 09:37 PM   #21
Pontiac1976
I'm guessing the back one is the butter fly adjustment. Does the carb have a name it does look like Rochester, but should be lower part of the carb near the front or front side It might be sealed off or have a plug over it if it never been rebuilt.
Old 06-13-2022, 08:51 AM   #22
Corts60
Just here to tinker
Corts60's Avatar
I think you’re talking about the idle/air adjustment whereas I believe the OP is asking for the idle rpm adjustment.
Old 06-13-2022, 10:46 AM   #23
jayoldschool
Moderator
What is the actual make/model of this carb?
Old 06-15-2022, 05:44 PM   #24
Shugalou
Shugalou's Avatar
have you checked the carb to intake manifold isn't leaking by spraying some carb cleaner? I was having a ruff runner and die when cold and my carb bolts needed to be tightened...nice easy fix.
Found my dad's old truck
http://67-72chevytrucks.com/vboard/s...d.php?t=563321
Newspaper Article Publishing the quest find my dad's old truck
http://www.theglobeandmail.com/globe...ticle12494281/
Shugalou is offline   Reply With Quote
Old 06-16-2022, 11:27 AM   #25
DLH
vacuum leak will cause high and rough idle. Get a can of carb cleaner and spray around the intake and carb mounting gaskets. Idle will change if you find a leak.
David
DLH is offline   Reply With Quote
