Old 01-01-2004, 02:01 PM   #1
Ont67shortbox
Question disc brake conversions
Can anyone tell me if there is a disc brake conversion kit that uses the drum brake spindles, or do i have to change spindles as well, thanks in advance , the truck is a 67 shortbox
Ont67shortbox is offline   Reply With Quote
Old 01-01-2004, 02:18 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Got to change the spindles on all of the different kits.
Old 01-01-2004, 02:41 PM   #3
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
classic performance products (i think, have a catalog around here somewhere) sells a kit to use the stock drum brake spindles, but it uses gm car brake rotors, so you would have the small 5 lug car pattern on the front. it wouldn't be a kit i would want to use anyway, the car rotors are smaller diameter, and who wants a car pattern anyway? plus you would have to get the rear axles redrilled to car pattern to match.
if you want more info, pm me and i will find the catalog
tommie is offline   Reply With Quote
Old 01-01-2004, 02:43 PM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
There is a kit to put disc brakes on the drum spindles.It consists of a couple of brackets that bolt to the spindle and provide mounting points for the calipers.I had the link saved but lost it when I had a computer meltdown.The brackets seem pretty simple and supposedly the kit is just a bolt on.However I believe it cost around $150.00 or so.If you are looking to lower the truck too the cost of the brake kit plus lowering springs would still put you in a higher $$$ bracket than drop spindles and created a harder to alighn front end.
Try a brake search on 67-72 truck brakes and maybe you can find the link.I think maybe GMCPaul had these for sale at one time,but it may have been another BB vendor.If I find the info I will post it.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
