Old 01-01-2004, 02:04 PM   #1
ChevyDude
Changing out window regulators???
I need some help in the steps or procejure when removing the window regulators and replacing them . I went to do this yesterday and it seems the vent window must be removed first. Can anyone who has done this fill in the blanks for me and anyone else that might need help with this. How about a step by step lesson. Thank you very much for all your help guys!
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 01-01-2004, 02:09 PM   #2
neonlarry
neonlarry's Avatar
Check out this post.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 01-01-2004, 02:21 PM   #3
ChevyDude
Thanks Neon Larry. This is what I was hoping for. I cut and pasted what Bow-Tie-Bandit posted on 12-23-03, here it is for those who need this:
Door vent window
1. Lower the window all the way
2. remove the door trim panel
3. remove the door lock knob
4. remove the screws which attach the vent window lower
assembly to the door panel
5. loosen the inner and outer panel screws which are accessable
through the hole to the rear of the lower vent pivot
6. slide the main glass to the rear, away from the vent window
7. turn the complete assembly 90 degrees and guide it up and
out of the door
8. installation is the reverse of the removal
Door window glass and regulator
1. lower the glass completely, remove the window regulator
handle and the door lock knob
2. remove the door armrest and trim panel
3. remove the door vent window (above)
4. slide the main window glass forward until the front roller
is in alignment with the notch in the sash channel. Disengage
the roller
5. push the window forward and tilt the front edge up until the
rear roller is disengaged
6. return the window glass to the level positionand withdraw it
from the door
7. if necessary, remove the mounting screws and withdraw the
regulator assemblythrough the lower opening in the door
8. prior to installation lube the regulator mechanism with chassis
grease
9. installation is the reverse of removal
Alex
Old 01-01-2004, 02:44 PM   #4
krue
Designated A-hole!
krue's Avatar
I copied the instructions into the FAQ section, so I can find it when I get ready to do mine!
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
