Old 05-24-2022, 12:22 PM   #1
Braunschweiger
Help Front Alignment
I have front Suspension Alignment problems, I can't get my Camber to be negative adjusted. The starting point is 2,5" drop spindles and 2" inch drop Springs with 63er front and I have all the shims removed to get on the Driver Side from 1.5 ° positive to 0, Passenger Side are all out shims and I'm on ca. 1 ° even in the positive, actually I should nevertheless shims stappeln in lowering my UCAs are not reversed, I have the LCAs outside set to Jack about the hub to have free.
The blue jacks are free, just to safety.
Is my measurement setup wrong? It was recommended here once and it seemed right to me.
Greetings Harald
My 62 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=829782
Braunschweiger is offline   Reply With Quote
