Old 01-01-2004, 04:17 PM   #1
Injected68LS1
Injected68LS1's Avatar
Here's some install pics.
Here are pics of my installation of the week.
This is the front suspension:
1968 Chev SWB with 1998 Corvette LS1
305hp and 320 ftlb to the wheels (stock engine!)
AEM EMS and wideband O2 sensors
Bowtie Overdrive's 700R4, stage 3
Baer 4 wheel discs and 20s
http://iciclelanding.com/aperture?album=2049&view=album
Injected68LS1 is offline   Reply With Quote
Old 01-01-2004, 04:19 PM   #2
Injected68LS1
Here's the thread with the overall pics: http://67-72chevytrucks.com/vboard/s...7&pagenumber=2
This is closeup of the front disc:
Old 01-01-2004, 04:20 PM   #3
Injected68LS1
another
Old 01-01-2004, 04:20 PM   #4
Injected68LS1
The rear disc:
Old 01-01-2004, 04:21 PM   #5
Injected68LS1
the bracket setup:
Old 01-01-2004, 04:23 PM   #6
Injected68LS1
Here's my 7" dual diaphram booster and 1" bore master
Old 01-01-2004, 04:23 PM   #7
Injected68LS1
the other side
Old 01-01-2004, 04:24 PM   #8
Injected68LS1
As you can see I got my camera back. Hope you like the pics.
Old 01-01-2004, 04:50 PM   #9
onelow69
onelow69's Avatar
Love the wheels and the work you have done. Keep it up. And by the way happy new year.
69 Chevy Truck, 350, 400trans, Lowered 3.5/6, Disc brake conv, All early classic stuff. 62 Chevy Nova 350, 700R4, 2400stall, F9in, 3.70gear, AlburnPosi, Chevelle Disc Brakes, ect.
onelow69 is offline   Reply With Quote
Old 01-01-2004, 04:56 PM   #10
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Nice job that 's a sweet truck btw..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 01-01-2004, 09:49 PM   #11
Luv68's
Luv68's's Avatar
Tahat's awesome, I just started my frame last week, can't wait to get to that point. Looks Great!!!!
Luv68's is offline   Reply With Quote
Old 01-01-2004, 09:50 PM   #12
Luv68's
Luv68's's Avatar
Sorry for the dumb thumb should be "thats awesome"
Old 01-02-2004, 01:12 AM   #13
ChrisK10
1971 C20 Custom Camper
ChrisK10's Avatar
You could have just edited it...
'71 Chevy C20 Custom Camper, 454, TH400
'97 GMC K1500 5.7L
ChrisK10 is offline   Reply With Quote
Old 01-02-2004, 04:29 AM   #14
Low69CST
Hey injected, where did you get your booster/master cylinder set up? Just like what i'd like to have. Any more pics of your truck? it looks awesome.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 01-02-2004, 04:38 AM   #15
72shadetree
KEEP ON TRUCKING
72shadetree's Avatar
sweet truck
72 cheyenne 2wd lwb
71 k20 sons
bassett va
72shadetree is offline   Reply With Quote
Old 01-02-2004, 05:28 AM   #16
dinnut
dinnut's Avatar
wow that is a trick master cylinder setup... that doesnt have fluid right? better put some that whole setup is incredible man!
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 01-02-2004, 05:32 AM   #17
NPilot1975
NPilot1975's Avatar
How much did you pay for the brakes system? I want to do the same to my truck.
1972 Blazer body...need to get a thread started for the rest of the story
NPilot1975 is offline   Reply With Quote
Old 01-02-2004, 09:56 AM   #18
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
wow looks like a new truck, it almost is
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 01-02-2004, 10:25 AM   #19
truck69
Thumbs up
WOW!! That is nice. In all your pictures the truck is spotless. Maybe mine will be that clean some day.
Truck69
truck69 is offline   Reply With Quote
Old 01-03-2004, 12:49 AM   #20
Injected68LS1
I like the look of the master and booster too. It turned out nice. I got the setup from ABS. American Brake and Steering in Orange, CA . Their number is 714-771-6549. Talk to Lucio.
It comes with a different bracket setup for the firewall. It moves it closer and it gets rid of that second link that mounts on the original bracket. And it uses the same mounting studs and the same hole for the pedal rod. You just have to drill a new hole on the pedal arm. I paid $370 for all of that plus a disc/disc prop. valve. I decided not to install the prop. valve because it doesn't really do anything except provide a warning switch. I just made my own bracket for the wilwood prop. valve.
Anyone want to buy my disc/disc prop. valve? It's a brand new brass valve. Looks good.
Old 01-03-2004, 01:03 AM   #21
Injected68LS1
here's another shot
Old 01-03-2004, 01:04 AM   #22
Injected68LS1
damn. I really need to get that hood painted.
Old 01-03-2004, 01:36 AM   #23
Low69CST
Thanks for the info on the brakes. By the way, is that a Dyno in your shop???? man........i'm jealous!
Old 01-03-2004, 01:49 AM   #24
Injected68LS1
Yeah. That's a dyno all right. It even has constant speed testing. You can set it for say 50 mph and you can tune car at a set rpm and vary the load(gas pedal). It makes it easy to tune an ECU or whatever else you want to do.
Old 01-03-2004, 03:46 AM   #25
Alexis
Member since 2000
Alexis's Avatar
How bout a whole side shot of that Very awesome work dude!
Alexis is offline   Reply With Quote
