Old 05-26-2022, 04:22 PM   #1
Phillip Owings
Phillip Owings's Avatar
Long Bed weight????
Hi Guys does anyone know how much a long bed weighs? going to pick one up tomorrow.
Phillip Owings is offline   Reply With Quote
Old 05-26-2022, 05:21 PM   #2
tutone
tutone's Avatar
Re: Long Bed weight????
It would only be a guess but I took one apart to cut it down
Floor two men to move ...200
Each side...one man.........80 ea
Tubs...................................20 ea
Front panel.........................40
End gate.............................60
My guess 480 or so counting hardware
:My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=807535
1972 K10 swb/1968 Camaro 350/4spd
1955 210 2 dr sedan/1998 RCSB Z71/1977 Jeep CJ5
tutone is offline   Reply With Quote
Old 05-26-2022, 06:04 PM   #3
YellowK5
Active Member
Do you want to sell the upper molding? My C20 needs some good used replaced..
YellowK5 is offline   Reply With Quote
Old 05-26-2022, 06:20 PM   #4
Phillip Owings
No mine are missing also so I will need them.
Old 05-26-2022, 06:56 PM   #5
Phillip Owings
thanks
Old 05-26-2022, 07:58 PM   #6
Phillip Owings
Do you guys think its worth $350.00 and a 2 hr drive I noticed some rust holes in the Bed. its 1000% better then mine and I wanted to keep the color original. but I didn't see the spots on both sides of the wires are I know how to repair that but just having second thoughts. what's your thoughts?
Old 05-26-2022, 08:44 PM   #7
tutone
tutone's Avatar
Floor repairs, as you know, will require some scrap pieces from another bed.
The reveal around the wheel well needs to be good. I have a similar long bed with the same rust and I would not let it go for that. Hope that helps. I cut them down and keep some floor scraps back for just such repairs.
:My build thread
Old 05-26-2022, 08:52 PM   #8
Phillip Owings
Thanks it does help.
Old 05-26-2022, 11:10 PM   #9
Jason Banks
Jason Banks's Avatar
$350 sounds fair to me
Jason Banks is offline   Reply With Quote
Old 05-26-2022, 11:43 PM   #10
Phillip Owings
Thumbs up Re: Long Bed weight????
I'm getting it tomorrow.
Old 05-27-2022, 09:26 AM   #11
1967-C10
1967-C10's Avatar
Great price if you willing to put some work into it.
I have scrap Bed floor panels, available.
let me know what you need.
1967-C10 is offline   Reply With Quote
Old 05-27-2022, 12:36 PM   #12
Caddylackn
Caddylackn's Avatar
There is a significant crease on the lower rear passenger side. The metal is stretched, so it will need to be cut or metal shrunk to get it straight again. The rest seems pretty straight. Actually the inside is really dent free. They must not of hauled much with it.
How are the top of the bed rails?
If you have to pay a body shop to make that bed perfect, I think you would be better to wait until a better one shows up. That one is good driver quality. Too bad the tailgate is missing.
1969 Custom Camper C20; Factree Air, 350/TH400/Dana 70U with C30 wheel cylinders, Disk brakes, H4 conversion, headlight relay mod, 3G 135 amp alternator. 7500 GVW
Caddylackn is offline   Reply With Quote
Old 05-27-2022, 03:54 PM   #13
May70
May70's Avatar
You will need no less than 4 men to move this and they better be in good health. Or have 3 really strong dudes but still that's a lot for 4 people. I've moved three beds with four men and a 10' move barely happened the last time. I paid 400 for a bed a few years ago in comparable shape it looks like assuming the floor doesn't have any rust through.
Bed prices just went up and so did shipping in the last few months. I was going to order a new bedside till I saw the price.
70 C20 Build link : Project Montezuma
http://67-72chevytrucks.com/vboard/s...d.php?t=794479
How to repair that rusted out 67-72 c10-c30! Please subscribe!
https://www.youtube.com/c/MaycoCustomRestorations
May70 is offline   Reply With Quote
Old 05-27-2022, 05:52 PM   #14
Caddylackn
Caddylackn's Avatar
I would build a wood beam out of 2" by 8"s to sit under the bed rail and use an engine picker. Pick it up 3' then drive a trailer or flat bed under it and haul it away. That is how I removed mine. I bet its at least 400#s.
Without a crane, bending over and getting it off the ground is the tough part. With two, you might be able to stand it on end and back a flat bed up to it and carefully lower it back onto the bed. Then use three people to pick up the other end still on the ground and slide it farther onto the bed.
You think 4 people for 400#s, that is only 100# per person. Nope, only if you are perfectly balanced and coordinated to lift exactly at the same time. It is usually 100# plus all the force fighting each other from not going up at the exact same time or forward movement so add another 100# of jerky forces.
You could call a tow company and ask them how much to pick it up onsite and move it to your trailer or truck bed onsite. Be worth a $100 to me to not have to try to round up another 3 guys, pick them up, drive them, and feed them and beer them to get their help, then drop them off at home.
Old 05-27-2022, 08:35 PM   #15
Phillip Owings
well I got it today. I'm happier than I though I would be. My father has a rollback so he was ok with picking it up for me. Here's a few pictures.
Old 05-27-2022, 09:55 PM   #16
Phillip Owings
Old 05-27-2022, 09:57 PM   #17
tutone
tutone's Avatar
You did good and nobody got hurt. You can piece mill parts off your old one and patch away. If you really watch your self you can retain your org paint with a little blending. Ive got a friend that raises 75-100 acres of tobacco each year. He has a 72 Cheyenne bed-trailer that he hauls when they set it. Ive offered him a grand for it and even told him I would put another bed on it and still pay the difference. The thing is nearly perfect. He wont turn it loose. Good day for you all around. Congrats.
:My build thread
Old 05-27-2022, 10:04 PM   #18
Phillip Owings
thanks
Old 05-27-2022, 10:07 PM   #19
Phillip Owings
Thanks I'm happy with it. Tomorrow im planning installing it.
Old 05-28-2022, 09:36 AM   #20
notsolo
notsolo's Avatar
Out of the dirt and back to work, nice score.
notsolo is offline   Reply With Quote
Old 05-28-2022, 10:07 AM   #21
yuccales
yuccales's Avatar
Philip, I know what your doing this weekend. Post a pic when you get that bed on the truck. Clocks ticking!
yuccales is offline   Reply With Quote
Old 05-28-2022, 10:14 AM   #22
68Gold/white
Well done!
The new bed is not perfect, but way better than original, and same color?
You should have no problems repairing this one!!
68Gold/white is offline   Reply With Quote
