Old 01-01-2004, 04:53 PM   #1
mhorning
mhorning's Avatar
question on alignment and steering wheel
I was changing the front tie rod end in the picture you see below and I got to thinking about my truck's alignment. My steering wheel isn't straight when I go down the road. I've had a guy look at it and he says the alignment is correct. He suggested that my truck may have a bent frame and that is why the steering wheel is out. Another guy told me that I could adjust this link to make the wheel straight. I figured you guys would know. If I readjust this will I screw up my alignment?
63 Chevy C10
86 Chevy K10
mhorning is offline   Reply With Quote
Old 01-01-2004, 06:19 PM   #2
Hipshot
alignment
i dont know if the are the same but on my 78 2wd i just pulled
the steering wheel & centered it..good luck
gordy
78 GMC Stepside SB
79 Olds Toronado
"What goes around comes around"
Hipshot is offline   Reply With Quote
Old 01-01-2004, 06:50 PM   #3
BaggedC10
Under construction!
BaggedC10's Avatar
Originally posted by Riptide's 78p/u
the correct procedure is to center the wheel, the adjust the toe from there...take it to a different alignment shop....
Correct!
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 01-01-2004, 11:52 PM   #4
mhorning
mhorning's Avatar
thanks guys, I figured that might be the answer
63 Chevy C10
86 Chevy K10
Old 01-02-2004, 12:16 AM   #5
Russell
Professional Grade
Russell's Avatar
lol, I would just pull the wheel off when I've got the wheels to a known straight position and put the wheel on centered
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 01-02-2004, 12:27 AM   #6
mhorning
mhorning's Avatar
Someone, correct me if I'm wrong but I don't think you can. There's a plastic horn ring that prevents you from putting it on only one way.
63 Chevy C10
86 Chevy K10
Old 01-02-2004, 12:41 AM   #7
C&C Chevy
C&C Chevy's Avatar
I pulled my off to straighten it too. I have a Grant steering wheel.
Robert
Current:
1986 SWB Silverado 4.3 / TH400
Past:
1985 SWB Silverado 305 / TH350 - sold 1995
1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007
C&C Chevy is offline   Reply With Quote
Old 01-02-2004, 01:17 AM   #8
Russell
Professional Grade
Russell's Avatar
Mhorning, you can slide that ring around however you want, how else could you turn the wheel around 3 times?
