Old 01-01-2004, 05:07 PM   #1
72superBB
72superBB's Avatar
Power steering box
What years of chevy trucks will the power steering box fit our trucks? Do the 73 & up fit and already have the quicker steering turning ratio?
thanks
Ron
Life is full of choices and a Chevy is the best choice.
1990 Chevy SWB
72superBB is offline   Reply With Quote
Old 01-01-2004, 05:17 PM   #2
dinnut
dinnut's Avatar
some of th e 73 up ones work. they have to have the right threads on the holes in the box i think to work. they work up to a certain year when they changed to metric. they have a 3.5 turn to turn lock and our trucks have 4.5 turn to turn lock.
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 01-01-2004, 05:21 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
73 to 87 work fine. Later years got the o-ring type of p/s hoses instead of the flare type. Just convert the pump fitting to an o-ring one if you need to.
Old 01-01-2004, 05:24 PM   #4
72superBB
72superBB's Avatar
They will work even with the remote reservior that I have since it is a big block?
thanks.
Ron
1990 Chevy SWB
Old 01-01-2004, 05:28 PM   #5
Tx Firefighter
The box will be either o-ring or flare type. The box fitting can't be changed, so use the hose to match the box and switch the pump fitting.
The fitting in the back of the pump unscrews. Two types of fittings, o-ring and flare type. Use whichever one your hoses are.
