Old 06-01-2022, 03:31 PM   #1
8man
48 Window lift bar screws
I'm looking for a picture of the 4 screws that hold the lift bar to the window channel.
Then I'll be looking for the 16 total screws to do both windows on the 48 and the 54.
Thanks.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 06-01-2022, 03:46 PM   #2
youngrodder
youngrodder's Avatar
Re: 48 Window lift bar screws
Thanks.
If memory servers they are just 1/4-20. I used shallow (like 1/2" or 3/4" in length) SS button heads. Being button heads, they don't interfere with the roller wheels. Taper head screws would probably work too. I just had some button head SS bolts around so I used them. I used the same bolts on my last two builds with no issue.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 06-01-2022, 05:10 PM   #3
8man
Thanks Marc, I tried some button heads, but the heads are too big to go in the channel. I may take a drill and belt sander and reduce the heads to make them work.
8man-aka Robert
Old 06-01-2022, 07:12 PM   #4
jweb
jweb's Avatar
It's been awhile but I think I used something like these:
https://www.mcmaster.com/90910A492/
They have several different styles and you can see the head diameter on each of the part drawings.
1951 Truck, LS1/4L60
1964 Suburban, current project
2014 Silverado daily driver
1953 Westerner "canned ham" trailer, rebuilt
1974 Prowler trailer, rebuilt
jweb is offline   Reply With Quote
Old 06-02-2022, 12:15 AM   #5
joedoh
joedoh's Avatar
i seriously dont know why those window channel screws are so over-engineered. 4 fine thread 1/4-20 for a compression fit? most I had to drill out because they would rust on and the clutch head would strip.
on a couple I would just use self tapping pan head because the threads were so boogered. unless rolling the window down (there is no force on the screws rolling up) caused all 4 screws to shear you'd be in tall cotton.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 06-02-2022, 12:31 PM   #6
8man
Thanks for all the help.
I used 1/4" x 20 x 1/2" button heads on the window I'm working on and they work great. They stick to the Allen wrench pretty well to stab them into the holes to start them.
8man-aka Robert
Old 06-02-2022, 12:44 PM   #7
youngrodder
Same reasons why I used them on my last (2) builds.
Marc
Old 06-02-2022, 12:45 PM   #8
8man
Yep, after you told me that, I went to the bold bin and found some. Thanks for the advice.
8man-aka Robert
