Old 01-01-2004, 10:06 PM   #1
chevyfan420
Question fuel pump
My recently purchased 79 Chev came hooked up to propane, and I'm going to switch back to good ole' gasoline. I pulled the existing fuel pump off to put a new one on. when i got it off, it had 3 fittings on the bottom. one goes to the tank, one goes to the carb....so where does the 3rd one go? it is a nipple type fitting and has a small hole in the end. It blows when the pump is used. does go to the charcol canisiter?
80 Chevy K10 350/350turbo
86 Chevy 1/2 ton shorty project truck
79 Chevy 1/2ton 350/350turbo
not much to look at... ***Retired***
97 Chevy C1500 4.3/5 speed.....daily driver
chevyfan420 is offline   Reply With Quote
Old 01-01-2004, 11:29 PM   #2
phantom dually
Project92 SWB stepside
phantom dually's Avatar
one is a fuel line inlet, the other is a return or a vent, and the other goes to the carb.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 01-01-2004, 11:35 PM   #3
Mike76251
The third line (return) was designed to circulate gas through the system to prevent vapor lock. It works pretty good until you get a load of California gas in the summer. Not much will prevent that crap from changing state as it is so "light".
Mike76251 is offline   Reply With Quote
Old 01-02-2004, 11:42 AM   #4
chevyfan420
so i can run an ordinary fuel pump that has one feed and one return?
Old 01-04-2004, 12:27 AM   #5
RodKnockin
you can just plug that one off just take the nipple off, and put a plug in it, if its removable. I plugged many of the off in the past witha small piece of hose and a blocked plug just use real hose clamps, instead of the sqeeze type.
RodKnockin is offline   Reply With Quote
Old 01-04-2004, 03:21 AM   #6
crackajacka
Stylin
crackajacka's Avatar
yea i did that but i have to leave my gas caps loose so the pressure doesnt build up and blow some hoses off lol.... anyone know of a way to fix that btw? not tryin to hajack the post or anything just wondering
Ive been traveling for some time, with my fishin pole and my bottle of shyne.
Most Girls like finished products and just dont understand what a good addiction does for you
http://www.paulwall.us/
crackajacka is offline   Reply With Quote
Old 01-04-2004, 02:26 PM   #7
mike reeh
5 day ban, learn to behave.
mike reeh's Avatar
Been running "california gas" for years and never had a vapor lock problem even in the mountains.
Chevyfan: got any details on how that propane system was setup? Sounds interesting...
crackajacka: I bet your vent is plugged in your sending unit. Dont ask me how or why but it happened to me.. I ended up drilling it out for temporary use until I replaced the sending units.. It only happened to one of my tanks, too.. BUT that was with my entire fuel system setup and working like stock, even the charcoal canister.. If someone 86'd your canister, they may have plugged the vent at the sending unit.. If thats the case, you'll be building pressure. If I were you, I would start at the sending units and trace the vent lines up to the engine compartment.. they're plugged somewhere
mike
mike reeh is offline   Reply With Quote
Old 01-04-2004, 07:54 PM   #8
Mike76251
mike
Forgot to mention...........I was towing 7000 lbs through Grapevine Pass when I had the problems.
Old 01-06-2004, 11:38 AM   #9
chevyfan420
I have a big tank mounted at the front of the box. A line runs under the cab up to the inner fender where my vapourizer and regulater is mounted. The vapourizer is tied into a heater hose. It goes through both of those and into a strange looking carb that sits atop a factory GM spreadbore intake.
Old 01-07-2004, 12:05 AM   #10
mike reeh
mike reeh's Avatar
i find that fascinating.. let me know if you ever want to part with the complete setup.
mike
Old 01-07-2004, 11:05 PM   #11
1972C10
1972C10's Avatar
Engines last alot longer on propane Old hank Hill would be proud ;
Looses power thou that motor should be nice and clean inside with little carbon if its been run on propane since it was new or rebuilt.
1972C10 is offline   Reply With Quote
Old 01-08-2004, 12:27 PM   #12
chevyfan420
ya, it dosent quite have the power it could but i can live with that. one nice thing about is that it needs no warm up time. it can be the coldest day and it fires right up and sits at an idle.
Old 01-08-2004, 04:52 PM   #13
crackajacka
Stylin
how bout mileage? how much does it get? i might look into it.
