Old 06-05-2022, 03:56 PM   #1
DoubleL
DoubleL's Avatar
Windsheild wiper issues
My wipers will work occassionaly but keep freezing up and stopping with a clicking noise. If I complete remove the wiper blade they will run without stopping. The resistance from the blades is stopping the motor from working. It tries to run but it just clicks, Wiper motor? What do you think?
My 1965 C-20 project
https://67-72chevytrucks.com/vboard/...d.php?t=835095
DoubleL is offline   Reply With Quote
Old 06-05-2022, 04:02 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Windsheild wiper issues
Wow. Usually people complain about not having enough resistance.
If it were me I'd pull the wiper cowl and see if there isn't something binding in the wiper transmission, from the motor to the wiper blade mounts.
And I'd check the grounds on my gauge panel. Since the wiper motor grounds thru the switch to the gauge panel.
Old 06-05-2022, 07:33 PM   #3
DoubleL
DoubleL's Avatar
So I removed the wiper assembly and the ends are very loose and might be binding up.
Old 06-05-2022, 09:11 PM   #4
The Rocknrod
Moderator
Wow.
I would get all that "stuff" and rust off both of those.
