06-06-2022, 07:57 PM | #1 |
1972 k10 battery cables help
Does anyone know what length both battery cables are for a 72 k10 with a 350 and A/C. Looking to route them as they were from the factory and any brands/places to get a good quality cable. Also which side of the battery is the positive supposed to be on? Passenger side?
06-07-2022, 07:54 AM | #2 |
Re: 1972 k10 battery cables help
batterycablesusa.com , Order or build your own , Nice stuff .
https://67-72chevytrucks.com/vboard/...d.php?t=833631
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
06-07-2022, 10:10 AM | #3 |
Carpe manana
Roger Koop (member here) was selling a decent set of repro battery cables with the correct side post connections. A search or PM should turn up that information. Positive is on the driver side of the battery if I recall.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
06-07-2022, 10:21 AM | #4 |
72 C10 lwb fleetside -stock 350/350 combo |
06-07-2022, 07:39 PM | #5 |
Does anyone know the lengths of both cables?
06-08-2022, 08:45 AM | #6 |
+ 44" and - 25"
06-08-2022, 09:22 AM | #7 |
Opened up the Roger Koop repro's..........27" & 44" is what I got.
Ron 1972 Cheyenne Super 1/2 ton LWB 4x4 - Grapefruit Yellow / White |
06-08-2022, 11:01 AM | #8 |
06-08-2022, 11:02 AM | #9 |
06-08-2022, 12:26 PM | #10 |
1972 350 with A/C
Marking on 44" cable = 6093TLP Marking on 27" cable = 4784TAL I can't measure the wire gauge, but based on my micrometer measuring the OVERALL thickness of the insulation & wire (.428) I'd say this is a 2 gauge. Hope that helps...........
06-08-2022, 02:12 PM | #11 |
How long is the aux wire on the positive cable? Any idea on the gauge of it? Does the ground wire have a extra wire also? If so how long is it ect.
06-08-2022, 02:59 PM | #12 |
Both have a secondary wires measuring .178
+ wire is 18" long - wire is 17" long I didn't state earlier, but this is for the factory side mount battery, NOT the top mount. Not sure how much difference it would make, just pointing it out.
06-08-2022, 04:48 PM | #13 |
Thanks for taking the time to answer my questions... You gave me all the info I needed.
