06-12-2022, 06:42 PM | #1 |
Radiator lower hose trouble
Put in a summit Blueprint motor SBC. Stock lower hose won't work. Aftermarket alumumn Radiator. Air compressor hangs to low. Anyone out run into this problem ? If What hose did you used ?
06-12-2022, 06:51 PM | #2 |
Re: Radiator lower hose trouble
Air compressor?? really............show us a picture
06-13-2022, 12:15 AM | #3 |
I mean Compressor for air condition
06-13-2022, 01:00 AM | #4 |
Yes I get that, but how is an AC compressor interfering with the lower hose on a regular small block when the compressor is mounted off the head and top water pump stud. Can you give us a picture
06-13-2022, 10:02 AM | #5 |
Here is a pictures, as you can see bottom pass side.
06-13-2022, 10:53 AM | #6 |
This thread should help . I just looked at my 95 k2500 and it looks like that hose would fit . ?
http://67-72chevytrucks.com/vboard/s...d.php?t=468729
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
06-13-2022, 11:58 AM | #7 |
Okay, I didn't get it had the serp belt set-up. I had a serp belt on my 400 small block in my flat bed, but the setup I had was identical to the one on my suburban and had no issue using the factory hose. So that being said I don't know what to tell you there other than you may have to change the bracket kit
06-13-2022, 02:31 PM | #8 |
Maybe call their tech support and see if they recommend a certain part #. I would imagine one form a 92-98 truck hose would be the one to go with.
