Old 06-12-2022, 10:09 PM   #1
65Custom
64-66 Radiator
Hello all, wondering if anyone makes a cross flow radiator for the 64-66 trucks,
I'm planning to put a big block in my truck and a cross flow radiator is better cooling than a down flow radiator. So in my searches for a radiator I am not finding anything to convert a down flow to a cross flow for these trucks,
Has anyone done this conversion? What did you use? Or Am I just stuck with a down flow from one of the many suppliers?
Thanks in advance
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=366677
I must be
65Custom is offline   Reply With Quote
Old 06-13-2022, 11:12 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: 64-66 Radiator
I know US Radiator makes a triple flow for our trucks. Haven't eyed a cross flow myself. Someone else may have though.
Old 06-13-2022, 12:17 PM   #3
vin63
It's Better With Nitro
vin63's Avatar
Re: 64-66 Radiator
You can talk with Griffin Radiator about building one to fit the dimensions you want. I just had them build a radiator for an older AC Cobra replica kit car that I'm helping a customer get running again with an odd core size to fit that sloping nose and it was crossflow.
I run a downflow radiator (aluminum dual 1.25 tubes) in my C10 462 ci.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 06-15-2022, 08:00 PM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: 64-66 Radiator
RnD fabrication is a vendor here
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 06-15-2022, 08:12 PM   #5
65Custom
Re: 64-66 Radiator
That looks like a nice option but they are very proud of it
My Build Thread
I must be
Old 06-15-2022, 08:47 PM   #6
65Custom
Re: 64-66 Radiator
found this vendor and looks like a good option but it is not a cross flow
https://www.coldcaseradiators.com/pr...mance-radiator
Too bad that is seems no one is making anything that is a cross flow drop in for our trucks
My Build Thread
I must be
Old 06-16-2022, 09:07 AM   #7
urmyboyblue
Re: 64-66 Radiator
My 427 BBC runs cool with a standard design vertical flow radiator and an electric fan. Champion sells several different radiators for different power ratings.
urmyboyblue is offline   Reply With Quote
Old 06-16-2022, 08:42 PM   #8
65Custom
Re: 64-66 Radiator
Thanks for the response, guessing I will be going with a down flow which will be a more original looking under the hood and and less aggravation installing it as well.
My Build Thread
I must be
Old 06-17-2022, 09:40 AM   #9
verdell
verdell's Avatar
Re: 64-66 Radiator
My brother runs a Griffin cross flow (27.5" x 19") and dual fans with his built 468 Big block and it has been good. I, on the other hand, tried the Griffin and it came apart after 2 years so I went back with the Speedway 28" x 19" crossflow and a 18" T-bird/Cougar fan.
verdell is offline   Reply With Quote
Old 06-17-2022, 11:57 AM   #10
theastronaut
theastronaut's Avatar
Re: 64-66 Radiator
Check reviews before ordering...
theastronaut is offline   Reply With Quote
Old 06-17-2022, 05:15 PM   #11
65Custom
Re: 64-66 Radiator
Originally Posted by verdell View Post
My brother runs a Griffin cross flow (27.5" x 19") and dual fans with his built 468 Big block and it has be good. I, on the other hand, tried the Griffin and it came apart after 2 years so I went back with the Speedway 28" x 19" crossflow and a 18" T-bird/Cougar fan.
Hey Thanks for posting this, I may check to see if that will fit in mine and what is required to mount this in place especially since the exact fit version is twice the price of the universal cross flow.
My Build Thread
I must be
Old 06-17-2022, 05:33 PM   #12
cwcarpenter98
cwcarpenter98's Avatar
Re: 64-66 Radiator
You'll have to change the mounts for a cross flow, but if you can find one that fits in the available space, it would probably work
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 350, Saginaw 4 speed
