Old 06-13-2022, 01:48 PM   #1
chris989
Muffler upgrade
Hello All,
I wanted to share my experience. I would have never believed the difference if someone just told me.
My build is simple. 350 tbi with a small lunati cam
.437"/.454"
207/213 @ .050
250/256
header, 2.5-3" exhaust, stock chip.
https://67-72chevytrucks.com/vboard/...d.php?t=696544
I have been running a 3" high flow cat and a 3 inch turbo muffler (necks down to 2.25 inside) and at 3500 rpms it didn't have a lot of pull left.
I always thought it was the cam or heads causing this. My state lifted the smog requirements so i finally tried a new set up. My motor pulls easily to 4500 rpm now before the TQ falls off. It is night and day different. If I had not driven it both ways i would not have believed it.
The new set up is a glass pack along with a Jones Max Flow.
https://www.summitracing.com/parts/JEX-MF2289
Anyway,, before this I was thinking about a set of heads or a 406 dart block for more stroke. I am glad I didn't. I am excited to see if my mileage increases on my next camp trip while towing.
Chris
chris989 is offline   Reply With Quote
Old 06-13-2022, 03:59 PM   #2
blazer2007
Re: Muffler upgrade
What is it suppose to do with 2 mufflers attached like that and is it loud or nice and quiet ?
blazer2007 is offline   Reply With Quote
Old 06-13-2022, 05:05 PM   #3
chris989
Re: Muffler upgrade
I had the glass pack laying around but by itself it is too loud.
I run a Jones max flow on my 78 ford f250 and it sounds awesome but alone it would be too loud for my daily driver.
the two together have a great sound while being mostly quiet. Get in the gas and it sounds great and at cruise i can hardly hear it.
Old 06-14-2022, 07:07 AM   #4
cadillac_al
Re: Muffler upgrade
The catalytic must have been clogging.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 06-14-2022, 09:21 AM   #5
chris989
Re: Muffler upgrade
That happened to a friends camaro way back in the 80s. That car would barely run and we messed with it for a week until we cut the cat off. Someone probably ran leaded gas in it.
I find it odd that all the turbo mufflers neck down to ~2" inside no matter the ID of the tail pipe.
Old 06-14-2022, 09:38 AM   #6
mongocanfly
mongocanfly's Avatar
Re: Muffler upgrade
hmmm.... my mufflers are 2-1/2" pipe and id all the way thru..
they are knockoff magnaflows...1 set is magflow, the other is maxxflow after they changed their name
not sure what a turbo muffler is...is that a brand , or just the style?
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 06-14-2022, 10:18 AM   #7
chris989
Re: Muffler upgrade
It is style and look like this inside
Old 06-14-2022, 09:59 PM   #8
chris989
Re: Muffler upgrade
I wanted to double check the cat before i posted again. My cat is 100% hollow inside. Just for show.
All of the resistance was in the muffler. out of curiosity i might cut it open to see what happened. It came from Midas locally because I needed it and they where the only ones with it in stock at the time. (covid).
Old 06-14-2022, 11:37 PM   #9
mongocanfly
Re: Muffler upgrade
I had a cat disentergrate one time and plugged up my muffler on a s10 blazer I once had, it couldn't get out of it's own way til I changed the muffler
The maxxflows/magflows I have are a straight thru design , the tube inside the muffler is full of holes that I assume is surrounded by some sort of sound deadener, they arnt to bad loud, nice mellow tone
I drew the tube path on mine on this pic
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 06-22-2022, 05:59 PM   #10
Mike C
Mike C's Avatar
Re: Muffler upgrade
The Walker SuperFlow aka DynoMax mufflers are true size all the way through. They are the old Sonic Turbo of the 80’s designed by David Vizard.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-22-2022, 06:18 PM   #11
mongocanfly
Re: Muffler upgrade
I've got a set of Walker super quite high flow 2-1/2"...they step down to under 2in as soon as they go into the housing..
Mongo...aka Greg
RIP Dad
RIP Jesse
