![]() Join Date: Jun 2012
Painting Grille Center Moldings
Does anyone have experience painting the center moldings on a 85-87 dual headlight front end? How did you do it?
The center moldings that I got from USA1 have what appears to be white vinyl film over the area that gets painted. I would assume that this is just protection film and I would remove before painting? I was planning on scuffing the area that gets painted with maroon scotch brite and then epoxy primer, base coat then clear. Thanks
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
| Bookmarks |
