| View Poll Results: Can this easily be done | |||
| swap whole axle or spacer delete |
0 | 0% |
| cost effective |
0 | 0% |
| Voters: 0. You may not vote on this poll | |||
K30 Cab chassis Front axle spacers
I have a 88 Crew Cab Cab Cassis dually ( narrow dually rear end ) 4 x 4 that I am lifting a rebuilding and I love the narrow dually rear end ( always gets a double take ) Bur I want to know if I can remove the front axxle dually spacers to use regular style 2500 front wheels dished out and not in like the dually. I am doing a 6" lift and doing custom dually rears to hoefully closely match the front standard 2500 dished wheels. Long question short what do I need to do
Re: K30 Cab chassis Front axle spacers
You will need to replace the hub and rotor to srw type.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
I always wanted to custom-build front Budd wheels to be wider, like on Heavy Duty trucks, to run wide tires and have wheels match
| Bookmarks |
