06-27-2022, 10:54 AM | #1 |
C10 CLUB Y QUE!
Rack and pinion upgrade
Morning fellas.
Looking for some advise and direction. I've searched the furom but couldn't find anything on this product. Before i start. I have a 61 gmc carryal that i just pancaked the crossmember and now looking to upgrade the steering. From what I read the geometry changes after pancaking the crossmember and have read that one of the best ways to fix it is by going rack and pinion. Which one should I get? Also if i have to spend 3k on it might as well buy a drop member. I'm looking to stay under 1k. Here is one I've been eyeing and it's in stock Unisteer Performance 8011910-01 - Unisteer Rack and Pinion Conversion Kits Would this work? |
06-27-2022, 02:18 PM | #2 |
Moderator
Re: Rack and pinion upgrade
Havnt seen a Unisteer install yet, but here is a NoLimit install - http://67-72chevytrucks.com/vboard/s...d.php?t=465423
Oh wait Unisteer on a 69 pretty much the same - http://67-72chevytrucks.com/vboard/s...d.php?t=540249
06-27-2022, 02:46 PM | #3 |
C10 CLUB Y QUE!
06-27-2022, 04:35 PM | #4 |
Not sure this will help you and maybe the year is the issue (i have 1966) , but I installed a Rack system from POL, direct bolt on. Installed to dame easy honestly. Pics are attached and the small write up is in my build
John 3:16 - Saved me... God Bless |
06-27-2022, 07:49 PM | #5 | |
C10 CLUB Y QUE!
It's pretty much the same thing. If you wanted to could you go up another 2 inches of course you would have to notch the frame |
