Do I need 10 gauge wire for the power windows?
Hi all. I'm redoing some wiring for my power windows in my 87 Silverado. They're too slow and it's time to do the relay mod. I need to know how many amps the power window motors pull, in these trucks.
I have heard they can pull up to 30 amps. This means you'd need to use 10 gauge wire for the power windows. Is this true? If not, what size wire should I be using? Thank you! |
![]() Join Date: May 2015
Re: Do I need 10 gauge wire for the power windows?
I think they fuse them at 25-30 amp...but i think the amp draw is more like 5-10
Never seen 10ga wire on a window motor
Thanks! So 14 gauge wire to be on the safe side?
I'll take some pics of the job and post them up. Some people may be interested because I'll be adding automatic (one touch) windows. No more holding the button down like they did in the dark ages. haha! |
I'd start by asking what's the factory size wire.
While I'm in there, I may as well check the track alignment and make sure it's working well enough.
But how do you go about that if you have electric windows? I assume you could check it easily with manual windows. You'd just see if you could pull it up and down easily enough, by pulling on the glass instead of the handle. I don't think that's a good way to check if you have power windows. Maybe I'm wrong. |
Moderator
![]() Join Date: Oct 2008
Stock wiring is 16ga.
14ga should do everything you need it to. If your window motors are slow it's likely because the motors are worn out and the linkage is in need of service.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
Just here to tinker
Better to go bigger if in doubt. If the wire can’t handle more than the fuse…you’re asking for a fire.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
#8 | |
Moderator
14ga should work a treat. 12ga would be gilding the lilly and 10ga is just plain silly.
It's all new AC delco stuff. That's why I'm doing the relay mod. On the driver's side, replacing with new fixed the slowness problem. But on the passenger side, replacing everything had no effect. So I decided to do the relay mod.
Well here's the first round of work. Got a fuse box off amazon that seems up to the task. I have covers for the exposed connections. Some are also underneath, on the bottom of the tray. The tray is just a flat piece of aluminum that I cut and bent so it would fit. Now I just have to wire up the one-touch Viper 553T window module. Looks pretty straightforward, famous last words I know. But it will be pretty cool to have automatic windows on the old truck. Gets old in the drive thru, you know?
I'm going to leave enough wire so that the fuse box and it's mounting tray can fold back and hang over the side of the fender. In case I need the room to work on something else. Headlight relays will also be in that box. https://i.imgur.com/1Zd9QEX.jpg Last edited by bennylava; 07-10-2022 at 03:34 AM. |
Moderator
Did you dry lube the flocked rubber window tracks on the slow window?
Graphite lube in the tracks makes a fair difference.
#12 | |
Test image I'm trying to get them to be smaller:
#13 |
looks like 640 x 480 is probably right
| Bookmarks |
