any identification numbers on frame
Hello I bought what was supposed to be 1980 K10. Didnt look that hard at the numbers before I bought it from estate sale. AC truck 4spd near perfect 8ft bed.
205 transfer case Runs and drives. Paid 1400 for it The cab is a 1980 3/4ton 2 wd as is the title. The engine is for the most part orange has a few blue brackets on it. I want to know if there are any numbers on the frame that might tell year of production etc. Got a feeling mid 70s drive train with 1980 cab and grill. Thanks |
Re: any identification numbers on frame
cant remember for sure but I think there is a vin number on frame above the rear axle on the pass. side. Been wrong before but I remember seeing one on my bare frame years ago when I was rebuilding. I bet Someone else on this forum will know.
I've been told that there's a partial vin on top of the passenger side frame rail, near the back edge of the cab. I've never seen it myself, but I'm told it's difficult unless you remove the cab.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
#4 | |
Could be driver's side rail, depending on final assembly location, but true in terms of partial VIN, top of upper flange of rail and difficult to see. Should be an assembly plant location, model year code, and sequential portion of VIN, ie: FA123456 A = 1980 model year K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Thanks for your help
| Bookmarks |
