07-03-2022, 03:32 PM | #1 |
Frame compatability
My K10 72 frame might be bent.
What else will fit under the body? Do i need an exact year (or series) frame, or will a 73 and newer frame work just fine? And if I change frames, do i need also to change running gear? How late in model years can one go, before stuff starts not to fit? Maybe 80's? Even into the 90's? ideas? |
07-03-2022, 03:47 PM | #2 |
Re: Frame compatability
The Square body frames can work.
There is a lot of modification involved. They have a huge dip in the center of the frame. Here is one old thread I found. Link: https://67-72chevytrucks.com/vboard/...ght=frame+swap
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
07-03-2022, 11:20 PM | #3 |
Collision repair body shops should be able to straighten the frame. Have you looked into frame straightening through a shop?
07-04-2022, 06:53 AM | #4 |
Also the 69 -72 Suburban 4x4 frames will work. There are a few mods to make but much less than the square body frames. There may be other years as 67 and 68, but I have no experience with them..
:My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=807535 1972 K10 swb/1968 Camaro 350/4spd 1955 210 2 dr sedan/1998 RCSB Z71 |
