Old 07-05-2022, 11:09 AM   #1
louder50
1961 Frame Options?
I am looking at a solid 61 cab and doors. What options exist for a chassis for it? From everything I read the 60-62 chassis leaves a lot to be desired. I'd like to end up with a chassis I can drop a 350 into and have decent driveavabilty and lower it. I don't want to get into air ride or anything radical.
louder50 is offline   Reply With Quote
Old 07-05-2022, 11:43 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: 1961 Frame Options?
The front cab mounts are farther apart and the bed mounts are wider side to side on the '62 frame. So that's not something you can't overcome using say a 64-66 frame.
Old 07-05-2022, 01:03 PM   #3
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Yes, the 60-62 X-Frame is what it would have been on. But you can put it on a 63-66 frame with just drilling two new holes in the floor of the cab.
With a little more work you can put it on a 67-72 frame.
Do you plan on going with a custom suspension or stock. If stock and you want power disc brakes and power steering, 72 would be a good candidate.
See https://www.67-72chevytrucks.com/vbo...d.php?t=785810
66 C20 Service Truck:
Old 07-05-2022, 04:53 PM   #4
louder50
I would just want it to be able to be lowered and have a 350/350 installed without a bunch of hassle. I would want to install a newer rear with a highway driveable gearing.
Old 07-05-2022, 05:37 PM   #5
LostMy65
LostMy65's Avatar
60-62 parts are available, just not a good selection/support. If you can stay above 63 you'll be better off for parts. 66 is the latest technology for the 60-66 generation. How plentiful are the 60-66's in your area.
Old 07-05-2022, 06:08 PM   #6
louder50
I'm in the middle of Michigan so most of them are Swiss cheese.
Old 07-05-2022, 08:13 PM   #7
LostMy65
LostMy65's Avatar
Anyway, 67-72 is an option if you are having difficulty finding a 60-66.
If you can weld, you have more options.
