Old 07-05-2022, 02:34 PM   #1
aggie91
I'm just glad to be here!
aggie91's Avatar
12 bolt rear axles
Well guys I ran into a new one for me...
I have a '73 (per the title, '74 per the VIN) Suburban that I picked up and did some investigation on the rear axle for servicing it. It turns out it is a 3.07 gear with a factory LSD carrier and the pinion yoke takes a 1330 series U-Joint. The ring gear is stamped 14 43, which works out to a 3.071428571 ratio.
I also have another 12 bolt from a square body (not 100% sure what it originally was in before I got it). It is has 3.07 gears and an open carrier. The pinion yoke on this one takes a 1310 series U-Joint. The ring gear is stamped 15 46, which works out to a 3.066666667 ratio.
All the other 12 bolts that I have and have had in the past have the same pinion yoke size that uses the 1310 u-joint.
Has anyone else seen 12 bolts with the same ratio, but different tooth counts and a different pinion yoke?
Would GM make multiple sets of gears that work out to the same ratio for the same type of axle? What would be the reason to do so?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 07-05-2022, 09:39 PM   #2
Warrens69GMC
Warrens69GMC's Avatar
Re: 12 bolt rear axles
Probably the year manufactured has something to do with it. The early 74 may have had the R&P from a earlier run, and there could lie the discrepancy.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 07-05-2022, 11:17 PM   #3
SunSoaked
SunSoaked's Avatar
Get a 14 bolt and pat yourself on the back.
SunSoaked is offline   Reply With Quote
Old 07-06-2022, 08:30 AM   #4
aggie91
aggie91's Avatar
Why? That is not really an option since it is WAY overkill for the intended use.
Also, it would cost me $$ to get one when I already have a good useable rear axle.
Karl
The LST Challenge:
Old 07-06-2022, 08:32 AM   #5
aggie91
aggie91's Avatar
I am going to dig into the year manufactured also, but so far from what I have seen, the pinion yoke difference may be do to the fact that the original engine in the suburban was a 454. I have read that those had the 1330 style u-joints...
Karl
The LST Challenge:
Old 07-06-2022, 09:11 AM   #6
Warrens69GMC
Curious to see what you find out. I have a 1979 Suburban with a 454/TH400/3.73 open in my yard.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
