Anyone Running 5" Wide Front Wheels?
I'm building my 66 for street/strip duty and looking at 5" front wheels. What backspace are you guys running and with which spindles? I'll be running a Wilwood aluminum Pro Spindle that sets the hub out .41". Thanks!
Moderator
![]() Join Date: Dec 2012
Re: Anyone Running 5" Wide Front Wheels?
IIRC the stock 15" wheel is 5" wide.
Up through most or all of '64 the stock 15" wheels are 5", then 5.5" after that.
I have CPP drop spindles and stock 5.5" wheels (3.75" BS) on the front of my '66, with 1.5" spacers to clear the calipers and push them out closer to the fenders. The backspacing is effectively 2.25" It's dropped about 4.5" and clears the fender with 215/75 tires. ![]() ![]()
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
#4 | |
Just the normal drop spindle with cast-in caliper mounts, not the Modular version.
