![]() Join Date: Feb 2003
Engine ID
Probably barking up the wrong tree, but is there any way of identifying an engine that still has all the equipment installed and in the vehicle, other than checking the VIN number?
Re: Engine ID
what do you mean by 'identify' the engine? Are you referring to the engine class, bore, and stroke size? Or to the exact RPO production code associated with that engine?
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
Re: Engine ID
Wanting to identify as a 305 or 350.
Re: Engine ID
Always a way. Just involves a little looking in the right places.
Look on the link. You’ll find number locations pics and what the numbers mean. Some numbers like casting code are a little hard to see but with the right tools you’ll see them. https://www.mortec.com/ |
#5 | |
Re: Engine ID
I don't know what year they started, but some blocks have it marked on the drivers side rear upper surface. This is marked 5.7.
![]() Join Date: Oct 2009
Re: Engine ID
I like to reference the block stamping at the front passenger side where head and block meet. The 2-3 digit letter code is a good indication of size and application - recommend use this site for ref pics, and about 3/4 of the way down the page is the index for the letter codes that you can click on to see what yours is. https://www.nastyz28.com/chevy-engin...-stampings.php
Re: Engine ID
Thanks fellow members. You have given me plenty info to move forward. Appreciate it.
Re: Engine ID
5.7 would be a 350, correct?
Re: Engine ID
Yes. There's 61.02 cubic inches in a liter. There's some rounding involved, since the actual displacement of a 350 is 349.67 cubic inches, or 5.72 liters.
| Bookmarks |
