Old 01-02-2004, 01:43 PM   #1
Beyond
Rebuilding 72 for towing work
I'd like to fix up my 72 and make it a tow monster for hauling my race car. Since the car's a 71 I think it would be pretty neat them both being from the same era. Anyways, what would you guys recommend for doing this. It's a 3 speed on the tree, 350 that needs rebuilt.
Should I stick a big block in it with say a TH400? Or are some of these newer automatics any good for towing?
How about the coil springs? Mines got those little helper leafs on the back but not really the best setup I don't think for towing. Should I pull those out and use air bags?
Just looking for some ideas, gonna put the ol' girl back to work.
Beyond is offline   Reply With Quote
Old 01-02-2004, 01:52 PM   #2
'70_402
'70_402's Avatar
you can never go wrong with a big block maybe a 402 and a turbo 400!!!! if you going to tow heavy loads then go with the bags out back! no matter how much you upgrade your coils they will never be enough
'70_402 is offline   Reply With Quote
Old 01-02-2004, 02:21 PM   #3
veltex
veltex's Avatar
I tow daily with my 68 c20, bb and t400, giant rear coils and little overload doo dads, frame hitch, works great even in weather, however I am only towing 3500lbs closed utility w/tools. Your car and trailer and tools probably ways alot more. Sway bar in front made huge difference, night and day. Now gas mpg, I dont even want to talk about it. good luck
veltex is offline   Reply With Quote
Old 01-02-2004, 04:56 PM   #4
Beyond
Car weights 3280, trailer I'm guessing is around 1500 (steel deck, open center 18') so we're talking about 5,000 lbs weight behind the truck + generator, tools, etc. in the back of the truck. It'll be loaded down pretty good.
I can pull it pretty good behind my 95 350 GMC but it's lacking some on hills (not enough motor). I know the 95 ex cab is probably quite a bit heavier than my 72 C10 - do you reckon the 72 with bags in the back would handle that much load?
Old 01-04-2004, 03:49 AM   #5
1972C10
1972C10's Avatar
big blocks are nice for towing Maybe consider a 4L80E trans its basically a 400 with overdrive they sell kits to put them in non conmputer control aps now.. Those shocks with the coil springs on them help out alot my 72 used ta have the heavy duty rear coils ..Wich i have if you need them, and the helper shocks I hauled scrap with it all the time it did good for a half ton most i ever hauled in on a trailer was 8k
1972C10 is offline   Reply With Quote
