![]() Join Date: Sep 2018
Where did you relocate your battery to?
Where did you put your battery? Can you share some pictures and/or insite? I really do not like the look in the stock position.
Posted via Mobile Device |
![]() ![]() Join Date: Nov 2008
Re: Where did you relocate your battery to?
Behind driver's seat. I'm not overly happy with the location though. I bought a drop-down battery holder to mount to the frame but for some reason it doesn't fit. I need to revisit that idea.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
Under the cab on the frame with a drop down box. Had to cut the clamp bolt down because it ran into the bottom of the cab. It can be a bit of a pain to service it so I keep a new battery in it. You will want to make sure you have a connection for a charger somewhere that’s easily accessible. I also put some heat shielding on my exhaust since it was so close.
1955 second series, 3200 standard bed, big window. Owned since 1975, decided it was time to do a frame off. 327, 4L80e, Ford 9 inch. |
![]() Join Date: Jul 2007
I'm going to put mine behind the seat and use a battery intended for a 2000/2005 Cadillac Deville DTS. The battery is under the back seat of those and pretty low profile and is vented to the outside though tubes going though the floor.
Will run Red Top rotated 90 deg.
Behind pass seat
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
On the frame on the passenger side, behind the cab mount. Used a 47-54 patch panel to put a removable door in front of the seat on the passenger side hidden under my floor mat.
My Build Thread: 59 Apache - Lifelong obsession http://67-72chevytrucks.com/vboard/showthread.php?t=622133"]59 Apache - Lifelong obsession |
#8 | |
